Cases Which spray paint for case interior
Discussion in 'Hardware' started by dead beat, 20 Jan 2011.
  1. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Ok, I would like to spray the interior of my case satin/matt black. I was just wondering what paint people have used in the past.
    Should I prime the surfaces first?
  2. Cus_de_Sparta65
    Cus_de_Sparta65 "There is no dremel"
    24 Apr 2009
    I am thinking of getting a Cosmos S case and getting the interior done black. I don't know whether to get it done by a pro or try it myself!!
    I really do not want it to look like crap though as I have never painted any thing since infant school so I will probs go pro route.
  3. bagman
    bagman Minimodder
    18 Apr 2009
    you want 120 grit sanding paper, etching primer and some matt black spray paint and that is it really
  4. line2008
    line2008 What is this "dremel" you speak of?
    29 Apr 2009
    any ideas how much powder coating is for a whole pc case? sorry for the thread hijack
  5. chris66
    chris66 Minimodder
    10 Jan 2011
    It may be worth finishing it with matt polyurethane varnish (spray can – matt or satin). This will protect the paint finish a lot better, and can be cleaned with a damp cloth without damaging the finish.
  6. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    I was thinking of a bit of a rip out and internal case spray also .. and then rebuild with new bits ...
    In the past I have rubbed down the varnish levels of paint .. used self etching primer and then a automotive type spray (aerosol) finished off with a few fine layers of lacquer to seal the deal.
  7. LatinSpirit
    LatinSpirit Minimodder
    23 Apr 2009
    I'm thinking about spraying my Cosmos S, but I need to decide on what car inspired colour scheme I want to do. Black is nice and all, but at the same time I am tempted to do something more unusual.
    :wallbash: Decisions! :wallbash:
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
  9. bulldogjeff
    2 Mar 2010
    Have a quick look in my sig at bulldogs box and how I sprayed the chassis. A scotch bright cloth is all thats needed to rough the case up and make sure it's cleaned and dust free before you start spraying.
    Edit: just had a look I didn't go into to much detail about prepping etc.
  10. dead beat
    15 Feb 2009
    Did you prime the surface before painting?
  11. bulldogjeff
    2 Mar 2010
    Yeah. Otherwise you'll just end up with the paint flaking off.
  12. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    I've heard these guys are very good :]
    http://www.chilledpc.co.uk/shop/:rock:
  13. bulldogjeff
    2 Mar 2010
  14. Fantus
    Fantus Nothing to see here...
    25 Jun 2010
    From what I've read, and seen, the Halfords range of Automotive sprays come out quite well.
  15. bulldogjeff
    2 Mar 2010
    Thats what I used on both my builds, it's good stuff, pretty tough as well.
  16. dead beat
    15 Feb 2009
    Once primed and panited, is it wise to use something like a lacquer, or just leave the paint as is?
  17. bulldogjeff
    2 Mar 2010
    You don't have to but it helps to protect the finish. Also when you've finished painting if you've got the patience leave the whole lot some where warm and dry for 2 weeks to harden up. That way if you give it a knock it'll be able to take it.
    Where are you going o be spraying, by that I mean shed/ garden?
  18. dead beat
    15 Feb 2009
    I'll be spraying in the garden. I'm in no particular hurry and have another case that I can use temporarily while the paint sets
  19. bulldogjeff
    2 Mar 2010
    The reason I ask is the weather and temps can affect the finish, with matt paint you should be ok though.
  20. dead beat
    15 Feb 2009
    Oh ok.....yeh I think it should be fine.
    Entirely off topic, but just thought I'd mention, got my 2600k stable at 5.0Ghz with 1.4v on the Vcore. And that's with just an H50 cooling the chip. Been running prime95 for 4 hours now.
