Cooling Which Thermal Paste...
Discussion in 'Hardware' started by hamant, 28 Jun 2010.
  1. hamant
    hamant What's a Dremel?
    14 Jul 2001
    So, I've just ordered all the bits for my new PC which should be delivered tomorrow. However, I totally forgot about the thermal paste for the CPU/Heatsink. Now, I haven't built a PC for over 4 years and am not up to date with the latest stuff. Last time I user Arctic Silver and spread a small amount over the CPU die (Athlon 64) and then slapped the heatsink on.
    After doing some research, seems like Arctic Silver 5 might be the way forward. Is this the case, or are there some better products available?
    I also checked out some application methods on Youtube and a lot of them show that the paste needs to be spread over the entire CPU using a finder?!? Is this right?
    Thanks in advance.
    PS. The CPU is an i720 and I'm planning to use the stock heatsink that comes with it.
  2. jammy_fred
    jammy_fred Minimodder
    26 Jan 2010
    IMO you can't go wrong with Arctic Silver 5, Arctic MX-2 or MX-3.
    But if you are using the stock heatsink then it will already have some paste applied. I wouldn't bother getting better TIM unless you were planning to upgrade the Heatsink as well.
  3. McLovin9091
    McLovin9091 I Have used a Dremel
    23 Apr 2009
    I've just whacked on some arctic 5 on mine and temps seem good
  4. frojoe
    frojoe What's a Dremel?
    17 Dec 2008
    I've seen people have problems taking the stock heatsink off the processor when using the paste that comes on it, but this is purely anecdotal evidence, might not be a problem at all. I just put some mx-2 on my i7 at 4ghz, and the temps are pretty good with a titan fenrir considering the ambient temps were around 33 C this afternoon, with 90% humidity. Brutal.
  5. Arthur
    Arthur It's for 'erberts !
    24 Nov 2009
    Arctic silver 5.
  6. brave758
    brave758 Minimodder
    16 Apr 2009
    Use the stuff on there. Its dow corning tc-1996. A very big company with a very big R&D budget.
  7. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    Shin-Etsu or IC Diamond 7.
  8. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    Arctic MX-3
  9. Sexton
    Sexton Minimodder
    2 Jun 2010
    Arctic Silver Ceramique is good.
  10. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    MX-3
    or MX-4 if you can get hold of it (its slightly better - lower temps, more easily spreadable).
  11. Dark Matter
    Dark Matter Minimodder
    12 Mar 2010
    I have ordered some Arctic 5 as a guide how much should be applied, and is it better to apply it to the heat sink rather than the chip to avoid getting it on the motherboard? :)
  12. Teelzebub
    27 Nov 2009
    +1
    I use both of these. Not at the same time lol.
    Use a large grain of rice size in the middle of CPU. Before tightening twist to right and then to the left and then back to center and tighten fully job done.
  13. Guest-56605
    Guest-56605 Guest
    Gelid Solutions GC-Extreme 3.5g :thumb:
  14. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Thermalright Chill Factor III. I spent about 6 hours the other day finding reviews of various TIMs and this came out every time on top. I'm not sure why it's so underestimated, but it certainly beats the more well-known brands.
  15. hamant
    14 Jul 2001
    I evenly spread a small amount over the CPU using an old credit card and then strapped the cooler on. Not sure how it works as i'm not monitoring temps at the moment.
  16. Big Elf
    23 Apr 2009
    I've recently started using CoolLaboratory Liquid Pro again. It's a pain to get off but on my Core i7 at 4.2GHz it's given me a 4ºC drop in load temps compared to MX-2 and on my E8400 it's given a 2ºC drop at 4.2GHz also compared to MX-2.
  17. TheBlackSwordsMan
    TheBlackSwordsMan Over the Hills and Far Away
    16 Aug 2009
    I used IC Diamond 7 but it's expensive (10 bucks for 1.5gr for a differency of 2°) now i use Arctic Silver MX-2 or OCZ Freeze Extreme
