Hiya guys. I have just taken delivery on a Antec 1200 case. Now my problem is which way around to mount the psu as it fits in the bottom of the case?If i fit it the standard way it wont be drawing air from the case and blowing out the back would it?So do i fit it with the intake fan facing upwards instead ? Cheers Chris
I would fit it with the fan drawing air from inside the case, then it wont suck crap in from underneath the case, and it works as an exhaust fan (y)
