Windows Which Web Server?
Discussion in 'Software' started by alacritous, 1 Jan 2005.
  1. alacritous
    alacritous What's a Dremel?
    1 Jan 2004
    Hello,
    I have a server and I would like to server up my web page. I want a secure web server that is easy to set up and has php, mysql, etc. Security isn't really a major concern because (1) it's just a personal website and (2) it's not like it's going to be known worldwide. On my old server I used a web server called Abyss. It gave me everything I wanted, but I just wanted to see if there was any better. I've also heard of Apache but havn't given it any try yet.
    Alacritous
  2. xilron
    xilron What's a Dremel?
    22 Jan 2003
    Hey-
    I use Abyss on my server, works great. Haven't found anything better for home web hosting.
  3. puzzler_uk
    puzzler_uk What's a Dremel?
    7 Sep 2003
    IIS On a 2k3 Server. My choice because i use a lot of ASP and ASP.Net also slips right into MMC snap-ins and everything so administration is easy. Although may need a move beefy machine.
  4. koola
    koola Minimodder
    11 Jul 2004
    All you need is a Win XP Pro OS and phpDev.
    From the phpdev site:
  5. alacritous
    1 Jan 2004
    Couldn't be better, heh.
    Abyss was actually really great, but it just seems like other web servers have more advanced things. Or I'm just dreaming... I guess I'll go for Apache (phpDev). Although, I'm sure it's more secure than Abyss in terms of like methods, but since Abyss isn't known, Apache is probably less safe. Like I said though, it doesn't bother me too much.
  6. alacritous
    1 Jan 2004
    Wow phpDev is pretty awesome.
    This is a litte off topic but here it goes. Which is better, the forums that installed with phpDev (Inivison Board) or phpBB? (phpBB.com) But wait I have a question. Inivison Board isn't free, so is the board that phpDev installed a trial?
    (I solved the Inivison Board "trial". There is no trial, it's free but you must follow the rules and support costs, etc. Still, which is better, IB or phpBB?)
    This is even more off topic, but where can I get something that will portal whatever I have in the forums to my index page.
    Thanks,
    Alacritous
  7. Atomic
    Atomic Gerwaff
    6 May 2002
  8. alacritous
    1 Jan 2004
    OK well I installed phpBB.
    Now I just need a portal system. Can anyone recommend something? phpNuke seems a little complicated. I'd rather get something that is easier.
  9. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
  10. koola
    koola Minimodder
    11 Jul 2004
