Electronics which wire to connect to get a AT psu on without moboard connection?
Discussion in 'Modding' started by weazel666, 26 Aug 2002.
  1. weazel666
    weazel666 What's a Dremel?
    12 Jan 2002
    i know that it's connect the green to the black on a ATx so it will run without being connected to a motherboad .. but i don't know what it is for a AT power supply ? anyone know?
  2. linear
    linear Minimodder
    5 Oct 2001
    AT has a four-wire (some have just two) lead group that go to the power switch. Closing the power switch connects brown to black and blue to white. An AT power switch is just a DPST switch, but it carries mains current, so it can zap you good. Use great caution when handling live connections on an AT supply.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I think with the AT (as with ATX) supplies it may be important to have some dummy loading. A 4R7 10W resistor on the 5v line should be enough.
  4. linear
    linear Minimodder
    5 Oct 2001
    Good point, I've seen behavior ranging from extremely poor regulation all the way to "doesn't appear to start" without load present.
  5. Floydian
    Floydian What's a Dremel?
    30 Dec 2001
    Yeah, you need a 5volt resistance of some sort, I usually use a resistor'd LED :p
  6. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    every AT I charged up without a connection on the motherboard end worked fine, the atx needed a wire.
