Cooling White coolant.
Discussion in 'Hardware' started by redders, 9 Jun 2009.
  1. redders
    redders What's a Dremel?
    2 Feb 2009
    Has anyone ever seen any white coolant or dye? I guess it would look similar to milk, though that sounds a bit gross having milk pumping around your system!
    EDIT: I'm aware that you can get white tubing, but afaik you can't get white tygon, and I really want to use tygon :p
  2. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
  3. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Powder coat the tygon...?
    Pulling ideas out of nowhere atm.
  4. aquatuning
    5 Jul 2006
    That would be as wise as using milk for the coolant.
    Disclaimer: Please don’t try that at home kids!
  5. Guest-23315
    Guest-23315 Guest
    ^^ No, milk would be a brilliant idea in comparison to powdercoating tube.
    Lets think shall we. Tygon takes say 90* max?
    Hmmm... a powdercoating oven is over 200*
    I'll let you do the math!
    Sarcasm aside, I'd reccomend coloured tubing over dyes any day...:
    (and someone elses experaince)
  6. LT.BEECH
    LT.BEECH Minimodder
    23 Apr 2009
    mate thats a good site, when i water cool i'm gettin the tubbin from there deffo:clap:
  7. rickysio
    6 Jun 2009
    Which was why I stated I was pulling ideas out of nowhere.
    Spraypaint might be possible, but the tubing will/should be stuck in place if that is done.
  8. capnPedro
    11 Apr 2007
    You're forgetting that powdercoating works by making the metal piece you're painting electronegative. So yes, the baking wouldn't work, but as plastics are insulators, the paint wouldn't even adhere!
  9. redders
    2 Feb 2009
    Okay I really want to avoid this horrid build up from the dyed coolants - do you think the additives in the CLEAR feser one (anti corrosion + anti algae etc.) would cause a build up? Should I stick with just distilled water?
    Also - what is the best quality coloured tubing around?
  10. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    I would stick with plain ol distilled and some nice coloured tubing. Your water blocks after 6months will stilllook healthy and you wont have any nasty deposits.Coloured tubing is the future to be fair, it seems all the rage at the mo too!
    Andy
  11. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    primochill primoflex pro LRT white tubing is the best there is.
    DD is next.
    Everything else is third.
    White tubing is your *only* option.
  12. docodine
    docodine killed a guy once
    10 Feb 2007
    Milk is your fourth option. :thumb:
  13. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    i can imagine how nasty the milk situation would become after a little time.
  14. aquatuning
    5 Jul 2006
    Recent update on this FluidXP are working on the white coolant and as soon as it made we will have stock :thumb:
  15. Pookeyhead
    30 Jan 2004
    I hate to throw a spanner into the works, but here is my block after 3 years heavy use with blue UV dye in the system.
    Maybe it's when you use dye in a system that wasn't fully sterile to begin with that you get problems?
    When it was drained, the fluid was just as blue as when it went in. No particulates whatsoever, and as you can see, the block is almost the same as when it was new. My temps never changed throughout the entire 3 year period.
    The slight marking you can see is drying marks from the tap water I used to flush the block out after use.
  16. capnPedro
    11 Apr 2007
    My rig is lactose intolerant you insensitive clod!
  17. [+]EXEcuteER[+]
    [+]EXEcuteER[+] Cracking up the Plex
    13 Aug 2009
    fluidxp in white? so twice as thick as normal fluid xp? rofl . the density will kill the flow..
  18. aquatuning
    5 Jul 2006
    And why would it be twice as thick?
  19. capnPedro
    11 Apr 2007
    Density =/= viscosity
  20. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    i have a suggestion for some viscous white coolant............
