Modding wide radius bends?
Discussion in 'Modding' started by yeknom, 8 Jan 2009.
  1. yeknom
    yeknom What's a Dremel?
    23 Apr 2008
    hey everyone,
    how would you go about making a wide radius bend in say, aluminium?
    maybe my rather weak paint-fu can explain.
    any tips/ideas?
    thanks
  2. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    What's it going to be attached to?
    So if the curve is the side, then the top & bottom pieces would act like a jig, so as you bolt or rivet or whatever the alluminium down, the curve is held in exact posistion -if the alloy isn't too thick and the top & bottom are tough enough for this?
    Or you can make a jig from some wood to bend the alloy over. Heating the alloy in the oven (if it fits?) would make it easier to bend and i think letting the alloy cool in the jig will help to retain it's shape. Don't blame me if you burn yourself though :D
    You could always just make the jig a tiny bit tighter than required instead of heating the alloy, to try and form the desired shape
  3. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    I would find a form that you can bend over. Paint can, pipe, etc.
    mvagusta likes this.
  4. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    A while ago I needed some 180-degree, 200mm diameter bends in 25x3mm strips of aluminum. The bending worked easily enough by hand. I drew a semicircle with a compass on a paper and clamped a strip in a small portable vice. Then I just nudged here and there until the bend matched the one on paper. Your knee is the best bending tool by the way! Bending by hand left some small irregularities here and there but nothing you'll notice unless you know where to look.
  5. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    Bend it around something that has the same diameter (Steel Pipe is a good idea...) as that which you are trying to achieve. That seems the easiest and least prone to mistakes option.
    Laz
  6. mvagusta
    24 Dec 2006
    Actually yes, that could be much easier :D
  7. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    http://grizzly.com/products/G7148
    Slip roll is the proper way, 3 rollers, 2 are geared together, and feed the sheetmetal, and the 3rd one determines the bend radius by adjusting it in and out.
    The cheap way is to use a form and bend it by hand.
  8. yeknom
    23 Apr 2008
    Will you have to heat the metal in order to do this? Or can you just use a hammer and some wood?
  9. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    You'll need to be more specific. How thick is the metal you want to bend, and what radius do you need?
    Hammer modding is instant win though :rock:
  10. yeknom
    23 Apr 2008
    Probably 2mm aluminium. I'm gunning for a 25mm or 40mm radius
  11. Xtrafresh
    27 Dec 2007
    in that case a wooden jig, a hammer and a strong arm for polishing afterwards will be your best tools :)
  12. dylAndroid
    dylAndroid is human?
    31 Mar 2008
    For a complicated curve that's big and does not match any objects you can find, you could cut wood into an appropriately shaped setup.
    For example, you could cut your desired curve onto multiple (identical) pieces of plywood. These pieces would be setup in parallel or sandwiched together. Presumably the assembly would be also mounted to something else. Sand before using to make sure it's perfect, and you're in business!
    For more complicated materials that can bend or deform more than just along an axis, you can have each iteration of wood change.
  13. Zeroignite
    Zeroignite So I decided to simulate a Universe
    18 Jan 2009
    Al is probably soft enough to bend without resorting to power tools. The biggest trick will be to make sure that the bend is continuous, not a series of smaller, sharper bends. some sort of form is a must, but there is no reason you'd need to heat the metal. Anything hot enough to matter would be to hot to have in close proximity to your body anyway.
