Displays will this chain conversion work?
Discussion in 'Hardware' started by dave_c, 21 Oct 2011.
  1. dave_c
    dave_c Minimodder
    31 Jul 2009
    will this work with eyefinity or do i need to go out and buy a DVI cable?
    ok so i got
    HD5770 > Active Displayport to DVI converter > DVI to VGA converter > monitor
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Why are you converting the DisplayPort to DVI first? I'm sure you can just go straight to VGA.
    But to answer your question it depends what the first converter takes you to, if it's DVI-I, I reckon it should work, if it's DVI-D then no it won't.
  3. dave_c
    dave_c Minimodder
    31 Jul 2009
    awsome, thx bud. i got a Saphire Active displayport to single link DVI adapter, trying to get eyefinity to work, didnt even think to get to VGA (thick eh)
  4. noizdaemon666
    15 Jun 2010
    That'd be the easiest option if you're going to VGA, I think :) If your monitor has DVI as well though, get a DVI cable for digital goodness :)
  5. dave_c
    dave_c Minimodder
    31 Jul 2009
    will do mate, thanks for the help :)
