Build Advice Will this PSU suffice?
Discussion in 'Hardware' started by samozamo, 11 Sep 2010.
  1. samozamo
    samozamo What's a Dremel?
    19 Jul 2010
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Pointless link, just link to the item?
  3. bagman
    bagman Minimodder
    18 Apr 2009
    how much does it need to power?
  4. samozamo
    19 Jul 2010
    Would you not need to know what is powering?
  5. samozamo
    19 Jul 2010
    I don't know how to work that out from the components, that's why I'm posting.
  6. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Okay, what hardware are you planning on powering?
    Also, can you post a link to the PSU alone, not in a basket.
  7. samozamo
    19 Jul 2010
    Sorry I though it would be useful to see the parts it would be powering.
    http://www.scan.co.uk/Products/400W...ies-PSU-ATX-PS-2-80plus-Efficiency-UK-Version
    LN22762
    Antec 300 Three Hundred, Black Midi Tower Ultimate Gaming Case w/o PSU
    LN24874
    400W Corsair CMPSU-400CXUK Power Series PSU, ATX, PS/2, 80+ Efficiency, UK Version
    LN25351
    Samsung SH-S222A/BEBE 22x DVD±R, 12x DVD±DL, DVD+RW x8/-RW x6, DVD-RAM x12, IDE Black OEM
    LN26734
    500 GB Samsung HD502HI EcoGreen F2, SATA 3Gb/s, 5400rpm, 16MB Cache, 8.9 ms, NCQ
    LN28632
    Arctic Cooling Freezer 7 Pro v2.1 - S1366/S1156/S775/AM3/AM2+/AM2/939 Up to 130 Watts!
    LN28876
    MSI 770-C45, AMD 770, AM3, PCI-E 2.0(x16), DDR3 1600(OC), SATA 3Gb/s, SATA RAID, ATX
    LN29225
    1GB XFX HD5770, PCI-E 2.0(x16), 4800MHz GDDR5, GPU 850MHz, Cores 800, 2x DL DVI-I/HDMI
    LN32202
    4GB (2x2GB) Corsair DDR3 PC3-10666 (1333) Non-ECC Unbuffered, CAS 9-9-9-24, 1.50V
    LN34240
    AMD Phenom II X4 955 Black Edition, Sok AM3, 3.2GHz, 8MB Total Cache, Retail
  8. meandmymouth
    15 Sep 2009
    It should be okay but I would suggest going for a 500W instead.
    Oh and I would go for some 1600MHz RAM instead of 1333, they cost practically the same
  9. samozamo
    19 Jul 2010
    Can I get 1600MHz RAM on that MoBo?
    My friend seems to think 1333MHz is the highest it could have.
  10. meandmymouth
    15 Sep 2009
    hmmm, actually I'm not sure
  11. samozamo
    19 Jul 2010
    Yeah me neither, I had a look at it and it listed the ones it could do, but then at 1600MHz It has an * after it.
  12. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Yes but you will have to use the overclocking options on the mobo (it says so in the product title)
  13. samozamo
    19 Jul 2010
    Oh cool, thanks for clearing that up for us :)
  14. meandmymouth
    15 Sep 2009
    Yeah I saw the (OC) in the title but I was just being a bit dense
  15. samozamo
    19 Jul 2010
    So I'd just have to do a little bit of over clocking to be able to use it.
  16. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    Just about any time you get 1600mhz memory, you're going to have to overclock to make full use of it. If you just grab whatever high mhz memory is on the shelf, the memory's just going to underclock itself to whatever your cpu is at. There's all this math and junk to figure out exactly what the memory is going at for what fsb/multiplier speed you have, but the main thing is that just about every time you purchance 1600mhz memory or higher you need to overclock to make the most of it.
    You might also want to get a better mobo because if you get 1600mhz memory now and that same mobo, you won't be able to upgrade your memory in the future.
    Same could go for the psu. Your system could live off the one you posted, but if you expect to sli/crossfire upgrade in the future you're probably gonna need a stronger psu.
    Also, that HDD is only 5400rpm and while rpm isn't EXACTLY proportional to data transfer speed, it's likely to be slower than a 7200rpm HDD.
  17. samozamo
    19 Jul 2010
    Thats the best I can do really at the moment. I can't be spending any more really, is there anyway I could get anything better for my money then? Will I need to get a 500w PSU then?
  18. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    It depends on whether you're going to be overclocking that CPU. The Phenom II's get a bit power hungry when overclocked. Still, even then a 400W will handle it fine, so long as you stick to good quality models as you are doing.
    The reason you'd want to get a more powerful PSU is that a 500W+ PSU would be running in it's comfort zone rather than close to its peak load, giving you better effciency, less heat and less fan noise. My 430W PSU was pretty loud compared to the other components in my machine before I upgraded it, though obviously only when the CPU/GPU were under load and drawing lots of power.
    If you're not overclocking your CPU more than a few percent and don't intend on adding a second graphics card etc then a 400W will do just fine.
  19. samozamo
    19 Jul 2010
    Oh thank you thats brilliant then :D will help me stay under budget. Thanks alot for all your help!
  20. BenDavis
    BenDavis What's a Dremel?
    12 Aug 2009
    I'm the friend the OP referred to. From what I gather the MSI 770-C45 is only certified to handle 125W CPUs, which the 955 is, so surely that would mean there isn't any overhead for an overclock?
