As above. I'm wondering if a USB3 powered external Hard drive will be able to function properly if it's plugged into a USB2 port? (can it draw enough power?) TIA.
As long as it's a normal 2.5 inch drive plugged into a normal USB port it should do. Mine certainly does.
Depends on the drive, if USB 2 isn't enough to power the drive should come with either a Y-type cable [so it draws 2 USB ports worth of power] or a power brick so it can be used with older PCs without USB3
