Windows Win7 random BSODs - networking related
Discussion in 'Tech Support' started by Southern, 12 Mar 2010.
  1. Southern
    Southern Lovable Internet Nutcase
    7 Feb 2010
    Hello Gentlemen!
    Win7 64bit - all software updates applied
    Gigabyte P55 UD3L rev 1 - f5 bios applied
    2x crucial PC1066 RAM 2GB DDR3
    Sapphire Radeon 5770 - 10.2 catalyst drivers applied
    I had actually tried to post this entire message on my machine itself and then it ironically BSOD'd as I clicked create thread. Fffff....
    Anyway, so my PC seems to BSOD at present. Can be either idle or while playing tf2 or surfing.
    Oddly enough I have just started to fault find and have removed the ethernet cable, as at present I am still waiting for my wireless dongle to arrive, and guess what - no BSODs.
    Hmm!!!
    Any ideas where to go next? Perfect without the cable but would like to play online :)
    would be interested to hear if anyone has had similar trouble.:wallbash:
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
  3. Southern
    7 Feb 2010
    Hmm, thank you kind sir, I will download them and stick on a memory stick, just to be safe.
    I was dropping enough bricks when I recently updated the BIOS, so I don't really want a repeat performance. It also seems that the drivers have recently been updated as well - good news.
    +1 rep to you!
  4. Southern
    7 Feb 2010
    It was going so well!!
    A full 2 hours of fine operation, now it has started acting up AGAIN!
    I'm not entirely sure I have the right chipset drivers installed, either that or I have NO idea how to manipulate the chipset driver set and install. INF driver set = wtf.
    Anyway, with much swearing, back to stage one!
  5. Golygus
    Golygus Minimodder
    9 Oct 2003
    what file is causing teh BSOD?
    use Blue Screen View to tell you - the download link is near the bottom of the page.
  6. Jenny_Y8S
    Jenny_Y8S Guest
    Hey, there's girls in here too!
  7. Southern
    7 Feb 2010
    GENTLEMEN
    AND
    LADIES
  8. Southern
    7 Feb 2010
    Ok, so if my networking causes BSODs, is it safe to assume then that the board is faulty? RMA is now out of the question with the etailer but might a replacement board work? (I'll pick a different manufacturer, never again another gigabutt board!)
    In other news, I have verified I have the latest chipset drivers running for LAN, Chipset and Audio.
    Golygys, I've just seen your comment about Bluescreenview, I'm going to try that out and get back to you.
    I'll let you know what's going on afterwards.
  9. Southern
    7 Feb 2010
    Bluescreenview detects all the BSOD problems as coming from ntoskrnl.exe as an unexpected kernel mode trap. As far as I can figure out, this is usually caused by hardware failure, probably just on the chip used for ethernet.
    Can anyone verify whether I have this diagnosed correctly?
    Damn you, Gigabutt; I was just out of my 28 day warantee period with ebuyer when this started to happen.
  10. Golygus
    Golygus Minimodder
    9 Oct 2003
    Gigabyte will replace the board. I assume you have a business account with ebuyer then?
    If you have a cheap NCI lying around, try it.
    Also try a live OS (such as suse), and enable network see if that crashes.
    Also try a clean install of windows on a seperate HDD
    Also try the ethernet drivers from the CD rather than the latest versions.
  11. thehippoz
    19 Dec 2008
    you have the error code from the bsod southern?
    you could try to remake your swap file.. see that's a possibility with that error besides hardware drivers.. set it custom size for 4096-4096
    run prime95 and see if the ram is stable too
