Windows Window 7 drivers
Discussion in 'Software' started by wgy, 3 May 2009.
  1. wgy
    wgy What's a Dremel?
    28 Jul 2008
    ok, i have the win7 RC 64bit and in a few hours will fresh install, but-
    as far as drivers go, i have nvidia's win7 graphics drivers...
    but for my motherboard and sound card, it seems there is no specific win7 drivers.
    motherboard is a p5w dh deluxe, soundcard is a creative soundblaster audigy 2zs.
    is it possible to use xp/vista drivers or even the original install cd? noob question.. but i dont know if drivers are specific to only one OS.
    all help appreciated very much.
  2. klutch4891
    klutch4891 What's a Dremel?
    4 Feb 2008
    Go with the Vista drivers; they work just as well.
    wgy likes this.
  3. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    yep stick with the drivers that come with win 7.. least for now- you might potentially run into issues using nvidias- unless someone can confirm otherwise or you want to be the guinea pig =]
  4. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Most Vista drivers will work. There are some things that wont work properly or at all, but the essentials should be there.
    If you are running beta software you are already a guinea pig. ;)
  5. thehippoz
    19 Dec 2008
    lol yeah =] but you know the ntune guy is just waiting to pull the trigger on the new os
