Just mounted my window HDD. It is a Quantum Prodrive with 540mb! It sits in a hole next to the mainboard on the right side. I put a window into the right side, covered the surroundings of the HDD with aluminium foil and finally lighted it up with superbright LEDs... Well, watcha think?
Looks good. I did one a while ago.. Note the rough glue gun attempt at the edges, and i stuck a BLUE led in but it didnt light it all up
the mod is nice, but what is that next to your hdd? Alu foil? I think it would be even better if you could see inside the case though.....
The problem with being able to see inside the case is that I cannot make the hole any larger since the mainboard sits right next to it. Also I would have no way to mount it. Good idea though!
