Windows Windows 10 still using old icons
Discussion in 'Tech Support' started by geoboy333, 11 Apr 2016.
  1. geoboy333
    geoboy333 Sometimes I say something bright...
    28 Sep 2009
    Hi everyone,
    This is a really small problem and doesn't affect the function of my computer, just gets the OCD part of my head on edge.
    I upgraded to Win 10 pro back at launch and to the undiscerning eye everything has been fine. However, some of the system tray icons from windows 8 have persisted through the upgrade and the whole thing just doesn't feel like other Win 10 systems I've used. I can't quite put my finger on it, but it feels like the upgrade got me to 'Win 9.9' - not quite the full shilling.
    Specifically the remove hardware icon in this instance:
    still looks like this
    When it should look like this
    Call me paranoid but if it's underlining that the upgrade didn't do it's job completely then who knows what else didn't happen.
    I've googled around and can't find anyone with the same thing, or at least, is complaining about it.
    Thanks in advance
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    geoboy333 likes this.
  3. geoboy333
    28 Sep 2009
    Just tried that, no luck. Looking around it seems a lot of people actually have that icon so maybe it's not as worrying as I thought. Could be something to do with upgrading instead of fresh installing.
  4. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Run
    Code:
    sfc /scannow
    in an admin command prompt and see if that helps. It's cured a few little niggles for me sometimes.
  5. geoboy333
    28 Sep 2009
    Nope didn't fix it. Another difference is this:
    On another windows 10 system the taskbar right click looks like this
    While mine is this
    There's quite a few little things like this that make me scratch my head.
  6. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Upgrade to build 1511 via updates :)
  7. geoboy333
    28 Sep 2009
    Just saw it in the updates and am doing it now, fingers crossed.
  8. geoboy333
    28 Sep 2009
    Yup thats the ticket, both of the issues I pointed out are fixed and hopefully any I hadn't yet noticed are too. Thanks for your help guys, +rep for all :)
  9. noizdaemon666
    15 Jun 2010
    :duh: That'll teach me to assume everyone is always fully up to date lol
