News Windows 7 features improved multi-threading
Discussion in 'Article Discussion' started by CardJoe, 4 Jun 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Paradigm Shifter
    10 May 2006
    Anyone keeping an eye on Task Manager or similar in Windows 7 will probably have spotted this - and while it's vastly improved over XP/Vista... 7 still doesn't do it perfectly. If I fire up something like video encoding with multiple stages (some of which are single threaded, some multi-threaded, the first single threaded run is spread over all the cores of my i7 rig. If multi-threading then kicks in and utilises, say, 90% of all 8 cores, when that completes and a single threaded run takes over again, it'll be at 100% on just one of the 8 cores, rather than randomly fluctuating across all 8. At least, that's what I've been seeing in build 7100. Microsoft might have improved it even more with newer builds.
  3. OWNED66
    OWNED66 What's a Dremel?
    2 Sep 2007
  4. Rich_13
    Rich_13 What's a Dremel?
    12 Feb 2003
    Still its another bonus. Don't forget additional software needs to be written in a way which can utilise these cores as well...
  5. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    I don't really see the hurrah about Intel's turbo mode.
    1) this is Bit-tech, owners of Lynnfield will be overclocking, hence turbo goes off
    2) it will be a while before we see LGA 1156 chips going into hte normal sub £300 machine that people seem to want and since when did those people need a self overclocking quad core anyway!
  6. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I am in absolute amazement with how well Windows 7 has been, this is by far going to be one of the best OS I think I have ever used :)
  7. wyx087
    wyx087 Multimodder
    15 Aug 2007
    why would anyone turn off turbo mode?
    i5 will allow 8 threads together with proper bus to maximise its speed (rather than fsb)
    Win7 will be great, can't wait to get my hands on some SSD to use Win7
Tags: Add Tags
