Windows Windows 7 for £49.99 - Pre-order
Discussion in 'Software' started by cosmic, 25 Jun 2009.
  1. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Like bagpuss says it cant be ordered yet, but the prices are shown HERE on the left side under the 'Heres the deal' heading
  2. cosmic
    cosmic What's a Dremel?
    6 Jul 2007
  3. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    That's £30 more expensive than a normal OEM Vista.
  4. azrael-
    azrael- I'm special...
    18 May 2008
    Been wondering if you could use an E version key with a normal US version. Sucks not being able to upgrade from a previous version.
  5. cosmic
    6 Jul 2007
    - but MS is claiming that the UK versions will be priced the same as for an upgrade at launch, so your not loosing out. Upgrade versions will be available next year at the same price BUT the price of the standard versions will increase.
    Its all rip off pricing from MS anyway in my view when you look at what they pay in the US for the same product.
  6. adam_bagpuss
    24 Apr 2009
    £50 for retail windows 7 is really good i think. granted you gotta pre-order but im gunna cause i know when it hits the shelves the OEM copies are gunna be at least £80-90 and add double it nearly for retail
  7. azrael-
    18 May 2008
    The E versions cannot be used for upgrading an existing version of Windows. You can only install from scratch. Granted, that's what you often do, but I'd like the choice. Which I'd have if it weren't for those bloody Opera people. That alone will be enough reason for me never again to try a browser from Opera.
    By the way, the US preorder versions are only upgrade versions. Granted, they are a bit cheaper than the UK prices, but you MUST have an existing version of Windows to install.
    Now, if the key from an E version would work I'd download a copy of the "full" version from MSDN in a heart beat (once available for download :)).
