Windows windows 7 installation help
Discussion in 'Software' started by x_optic_x, 17 Oct 2011.
  1. x_optic_x
    x_optic_x What's a Dremel?
    13 Oct 2011
    hello all i am currently building my own pc and because my hard drive was out of stock it didnt come with the rest of the things. so i wanted to know if i install windows 7 on my old hard drive that has xp on and then later install it on to my new hard drive with the same cd and product key will it install onto the new hdd. thanks
  2. GoodBytes
    20 Jan 2007
    Yes, should not cause any problem.
  3. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Do you still want to keep the XP Install?
  4. gerardmcmanus
    gerardmcmanus What's a Dremel?
    11 Oct 2011
    That shouldn't be a problem, but are you planning on keeping your old pc, if so might want to think about the graphics and sound drivers etc, as you will have to install these on the old hdd before it will work properly with the new hardware. Then roll them back again to work with the old PC once your new HDD comes.
