Windows Windows 7 issues
Discussion in 'Software' started by mirciu, 21 Jun 2009.
  1. mirciu
    mirciu What's a Dremel?
    7 Jan 2007
    hi guys, i currently have some problems with w7 RC. everything is stable, runs better than vista, but for some reason it keeps downloading, killing my bandwidth. it starts always after about 10 after the logon. i've closed every other service and checked if the updates were the culprit, but no. i don't have clue what it needs to download. it;s been doing this for the last 3 weeks. any ideas would be much appreciated. thanx:confused:
  2. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    I don't have win7, but maybe it's uploading stuff to microsoft.
    By installing the rc, you have now become one of microsofts 'testers' so they can see how the os is performing.
    Nothing in this world is really 'free'.
  3. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Lol no. :rolleyes:
    How do you know it's downloading? Are you using some application?
    Could it be some updater of a program, such as Adobe?
  4. adam_bagpuss
    24 Apr 2009
    lol with what mr jack the thread
    life ? your health ? your mental stability ?
  5. mirciu
    7 Jan 2007
    i' was checking the download speed constantly, and all the other services were closed (adobe and everything) i had just the antivirus, but i blocked it's updates. the pc doesn't upload it downloads, but i don't have a clue what. either binary pron or some pleasing technical specs of some new ram he'd like to have, no clue about it.
  6. adam_bagpuss
    24 Apr 2009
    what app you using to check download ?
    also what app or service is requesting download ?
  7. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    press start-> write resource monitor and open the program.
    Look under the "Overview" tap and look at the "Network" section. Is there anything there that run lots of traffic? in which case, what?
  8. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    his bt client xD
  9. mirciu
    7 Jan 2007
    saw a spike in the bandwidth, and went to the ressource monitor, and nothing, nothing seems to show any highbandwidth usage..it's clawging all my network
  10. Smilodon
    25 Mar 2003
    Where do you see that there it's lots of traffic?
  11. cribcoch1
    cribcoch1 Old Age is a Bitch
    23 Apr 2009
    I checked Windows 7 on my dual boot system tonight, for a couple of hours I had Start Task Manager/Networking running, apart from the odd small spike nothing. Have you done a complete malware check on the system.
  12. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    Use Malwarebytes. Great program.
  13. Coldon
    Coldon What's a Dremel?
    14 Oct 2006
    where did you get your copy from? did you download it yourself from the MS site or is a torrent version.
    if its not from the official site chance are its one of the trojan infected versions floating around on the p2p sites.
  14. mirciu
    7 Jan 2007
    so, i've downloaded it from ms. i use bit defende to check the bandwidth, it has it built in, and i've checked as well the ressource monitor, it shows 2Mbs during constant spikes, with every piece of software active( or background) turned off, except the antivirus. i had the same issues sometimes with vista home premium, but not to this degree. anyway, thanx for the help, much appreciated
  15. Coldon
    14 Oct 2006
    your windows has bitdefender built in?!?!
  16. mirciu
    7 Jan 2007
    no, i bought the licence when i first got this pc, and it was the first piece of software installed on this win7
  17. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Do you have any network shares mapped?
  18. mirciu
    7 Jan 2007
    no, it's a lonely laptop, connected to a lonely router/dsl modem. no shares nothing, tried to see if hte same thing happened to my AAO, and it didn't. same copy of win 7 but the download spree was non-existent
  19. Hg
    Hg The game known as life
    3 Aug 2007
    Maybe its bit defender, try un-installing it and using AVG or something else for a few days, it sounds like it could be AV updates, if you use to get the same kind of problems with Vista
