Windows not detecting dual cores?
Discussion in 'Hardware' started by Anator, 4 Oct 2006.
  1. Anator
    Anator What's a Dremel?
    26 Feb 2004
    Ok, i've just upgraded to an Athlon x2 4400 from a 64 3000+. All boots up fine etc, device manager lists 2 processors which i think is correct? However task manager only shows a cpu usage graph for 1 core and I believe it should show 2 graphs for 2 cores.
    Was wondering if someone can point me in the right direction with this as this is my first dual core setup. Also just to clarify i did not do a fresh windows install for the upgrade nor do I want to except in an absolute last resort :p
  2. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    I believe you will have to do a reinstall in order to see both cores usage in task manager. I'm not sure if it will be using both cores. Try running some benchmarking programs to find out.
  3. DougEdey
    5 Jul 2005
    You need to install the dual core drivers :S
  4. -=ByteMan=-
    -=ByteMan=- What's a Dremel?
    16 Mar 2002
    re dual core not working
    Anator, you need to upgrade the HAL for your PC in device manager from the uniprocessor HAL to the multiprocessor HAL
    :jawdrop:
  5. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    if you download the amd cpu monitor off their site it'll show if both cores are being utilised by windows, and while your there you can get the drivers
  6. Anator
    26 Feb 2004
    Thanks for the replies everyone, unfortunately I haven't made much progress as yet.
    I downloaded the AMD power monitor which stated that multi-core suppourt is not enabled. I also downloaded&installed the dual core drivers but this has made no difference.
    Byteman, what exactly do you mean by HAL drivers?
  7. DougEdey
    5 Jul 2005
    HAL drivers are the CPU ones I believe.
    Are you using the mobo in your sig?
    EDIT: Make sure you're on the latest BIOS
  8. Anator
    26 Feb 2004
    Yep using the A8N-E with the latest bios.
  9. -=ByteMan=-
    16 Mar 2002
    Anator, the HAL is the hardware abstraction layer, which sits between the H/W and the Kernel. You can change it it in device manager, expand computer under device manager, and it will probably show ACPI UNIPROCESSOR PC, upgrade this driver to ACPI MULTIPROCESSOR PC, then instal the AMD Athlon 64 Processor driver from the AMD web site, for best cooling/performance.
  10. Anator
    26 Feb 2004
    I thought that's what you meant. Already checked that - currently got ACPI PC installed but the only other option to install is Standard PC.
  11. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    You need to repair-install. I went from a 4000+ to an Opty 165, and couldn't get the dual cores to show up until I repair installed my system.
  12. -=ByteMan=-
    16 Mar 2002
    Anator, when you attempt to change the driver, don't let the computer try and auto detect the driver. Select install from a list or specific location (advanced), then, don't search, I will choose the driver to install, you should then be able to choose the ACPI multiprocessor driver from the list. :duh:
  13. Anator
    26 Feb 2004
    :thumb:
  14. Anator
    26 Feb 2004
    Anyone got any other thoughts? I feel my worst fears are coming true and I will have to attempt a repair without my cd key :(
  15. rikbikboo
    rikbikboo What's a Dremel?
    3 Aug 2004
    go to task manager in view select cpu history and then select show 1 graph per cpu
    job done
  16. Anator
    26 Feb 2004
    That is already selected, but windows itself isn't utilising both cores :duh:
  17. DougEdey
    5 Jul 2005
    You should always keep your authentic CD key on the machine case.
  18. section8
    section8 What's a Dremel?
    19 Aug 2006
    LOL yes coz everyone has one of those... piracy has now been completely eradicated and everyone buys all of their software from the correct shops and vendors!!!! hehe only jk... i of course run all legitmate software... honestly...
    Scott B
  19. Cabe
    Cabe What's a Dremel?
    14 May 2002
