Windows windows XP and code problem
Discussion in 'Software' started by lord nicon21, 4 Nov 2006.
  1. lord nicon21
    lord nicon21 sexy *******
    29 Sep 2003
    OK hi all i hope someone can help me here.
    i that an IBM computer with a windows XP code on the case..
    so i was thinking i could use my windows xp OEM CD to install xp but use the code of the case but it wont let me could any one tell what i need to do?
    Thanks
    Ryan
  2. DougEdey
    5 Jul 2005
    The copy of XP you are using has to be exactly the same as the license.
    I.e. Home SP1 CD will not work with a Home SP2 License
  3. Firehed
    15 Feb 2004
    Well, it doesn't care about service packs.... but you can't swap an OEM install for a Home install disc. And, AFAIK, a branded OEM disc can't be swapped for a generic OEM key, or vice-versa (ie, a legally purchased OEM copy from Newegg won't work with the disc from the IBM OEM version).
  4. ỒĊBłůē
    ỒĊBłůē Also available in black
    2 Mar 2005
    I've installed XP SP1 using a pre-SP1 COA before.
    I haven't had to reinstall recently, but it seems that each time I do nowadays I end up having to ring M$ for a confirmation code; no problem there.
    I've read about folks being told that their license has expired and that they'd need to buy a new one - there'd be quite a row if one of M$'s automatons tried telling me that!
  5. lord nicon21
    29 Sep 2003
    so the only way round this is if i get an IBM copy (mabe i can g4u a ibm from work mabe that would work) thanks anyway
    damn M$ :eyebrow:
  6. Glider
    Glider /dev/null
    2 Aug 2005
    You can allways buy a new licence... :D
  7. lord nicon21
    29 Sep 2003
    thats just silly lol i've payed for one so i'm going to use it.
