Wire for extentions
Discussion in 'Modding' started by skullen, 6 May 2019.
  1. skullen
    skullen Minimodder
    31 Oct 2007
    Which AWG Wire to use for 24 pin a gpu as i am gonna have a go at my own.
    Thanks for looking :)
  2. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I am not an expert, but as far as I know 18 AWG will be perfectly fine. You could use 16 AWG but it's obviously thicker and thus bulkier. Whichever one you use, make sure you have the right size of crimps.
  3. skullen
    skullen Minimodder
    31 Oct 2007
    Cheers chap :)
  4. SHNS0
    SHNS0 Enter Plasma
    30 Mar 2017
    AWG18 is the standard.
    AWG16/15 is the maximum you can use with standard pins.
    If you're doing custom sleeved cables, I really recommend going thicker. They will offer a much better overall aesthetic, and the final cables will result more rigid and trainable to get those nice smooth curves.
  5. TechnoMod87
    TechnoMod87 What's a Dremel?
    13 Nov 2012
    awg 16 is good
  6. Pretizx
    Pretizx What's a Dremel?
    10 Feb 2017
