Modding Wire Management
Discussion in 'Modding' started by RW2112, 4 Aug 2003.
  1. RW2112
    RW2112 What's a Dremel?
    9 Jul 2002
    Thought for those interested I'd show you my latest attempt at cleaning up the insides of my case:
  2. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    Wow.... good job... I wish I could get mine that neat.
  3. RW2112
    9 Jul 2002
    Thanks. Just took a little planning and some dremel work in key spots to route the cabling through. Also got a local store to make some custom flat cables for me. :D
  4. ashyg
    ashyg What's a Dremel?
    3 Aug 2003
    No sound card?
    Onboard sound or what?
  5. ashyg
    3 Aug 2003
    I don't see RAM either.
  6. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    There's RAM, it's in the outer two slots, but the picture is at such an angle that the PCB for the RAM blends into the PCB of the mobo.
    Oh RW, I officially hate you for doing such a good job.
  7. ashyg
    3 Aug 2003
    Oh, yep, the little RAM-gripper-pin thingies are up.
  8. RW2112
    9 Jul 2002
    Correct, two sticks in the outer slots, and there is onboard sound. Motherboard is an Epox 8RDA+ NForce 2 board.
    BTW whypick, so nice to have a fan...:p :naughty:
  9. mushky
    mushky gimme snails
    24 Mar 2003
    another cable nazi :) glad to see i'm not the only one
  10. Gretzky
    Gretzky What's a Dremel?
    6 Nov 2002
    wow I thought my case was clean but your case is spotless. Great Job :clap:
  11. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    too clean for me :) needs some more expansion slots
  12. linear
    linear Minimodder
    5 Oct 2001
    nice one, and I totally agree with your sig.
  13. Dark_Blender
    Dark_Blender What's a Dremel?
    3 Jan 2003
    Wow that turned out really nice man. From the looks of it the IDE cables coem behind the mobo. I really like that. Good stuff :rock:
  14. herbs
    herbs Nobody but us chickens
    7 May 2001
    I need to do a few bits to tidy up but this is nearly done, it has 3 hard drives a cd rom drive. But its hard to keep it tidy as the psu only has 4 molexes on it.
  15. RW2112
    9 Jul 2002
    Thanks to everyone for the feedback, I appreciate it.
    About the IDE cables, yep, all tucked in the back. I measured out the distance between my CDRW and DVD along with the needed extra length. Then I went to my local computer store and had a custom ribbon cable made to spec for minimizing the clutter. All I needed then was a slot dremeled at the right locations to make the cables as flat as possible.
    The front panel connectors I ran behind the tray as well, then cut a hole behind the motherboard right at the connections on the Board. All you see as a result is a very minute piece of wire running immediately back under the motherboard. :hip: :hehe:
  16. RW2112
    9 Jul 2002
    Thanks Linear, I love your work on your machines as well. Matter of fact, that's where a lot of my inspiration came from; folks like you, Zap and all the others out here.
    As for the sig, yeah, almost everything I use in my cases come from one of those sources, except the cold cathode I have in my case. Latest thing I am adding is using Duplicolor Metalcast paint to give an anodized look to my Fan grills and the shroud on my Volcano 9 HSF, and the wire fan grills in my case.
    Starting work soon on stealthing my drives and possibly a stealth mounted blow hole...;)
  17. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    WOW! I had to double-check to see if the wires were even there! That's cleaner than my case when I remove the hardware.
    I think you would cry if you saw my case...
  18. malcs
    24 May 2003
    ok definately tidying up my cables tomorrow :D
  19. Wilier
    Wilier What's a Dremel?
    1 Apr 2003
    This was my effort
    Still needs a bit of work though :(
  20. Dark_Blender
    3 Jan 2003
    That seems also pretty solid with teh Mass amounts of HDDs there. How many GBs you got up in there?
