Peripherals Wireless internet PCI or USB
Discussion in 'Hardware' started by Totoro, 6 Jul 2011.
USB or PCI
  1. USB
    4 vote(s)
    26.7%
  2. PCI
    11 vote(s)
    73.3%
  1. Totoro
    Totoro What's a Dremel?
    27 Feb 2011
    I need to add a way to make my PC wireless but don't know if a PCI or USB option would be better, any sugestions?
    Thank you.
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Not much difference really, I'd personally go for pci as it's internal and won't be stealing one of my USB ports.
  3. Randomeclipse
    Randomeclipse Minimodder
    11 Jan 2011
    PCI all the way for me too and they're just as cheap as the USB ones too.
  4. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    PCI, I've had no end of issues with USB receivers.
  5. Totoro
    27 Feb 2011
    Ok, so general consensus says PCI, any sugestions for about £10 to £20 ?
  6. Deders
    Deders Modder
    14 Nov 2010
    I think PCI has lower latency than USB.
  7. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    i use THIS ONE in my HTPC. handles streaming from the network and web like a champ. the external antenna is nice due to my router being located on the exact opposite end of the house in a closet. i get a very good connection with it sitting on top of the HTPCs case.
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I'd do a wired connection first and foremost but if I had to choose it would be PCI
  9. samkiller42
    25 Apr 2006
    I setup someone's wifi using this: Novatech 54Mbps, It's not the most exotic of devices, but it works better than the stupid USB device we tried first. Only thing i don't like is the included software, other than that, it was fine.
    Sam
  10. Chebob
    Chebob What's a Dremel?
    5 Jul 2011
    Im using a £5 USB adapter from amazon and have no complaints whatsoever :)
  11. Totoro
    27 Feb 2011
    Thank you all for the replys, I will make sure I all works by wire first than install a PCI.
    Question solved
  12. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Here is a good Ebay seller for all things WLAN: http://stores.ebay.co.uk/wlan-sud
    He has great prices for large antennas and high power Wlan units. (remember to follow the law as some higher settings are not legal in some countries)
  13. Edwards
    Edwards Minimodder
    8 Oct 2010
    I'm a big fan of the Edimax PCI cards. for 10-20 pounds, this looks good. I have the EW-7728IN, and have been very impressed. Only thing i'd recommend is to find the latest drivers yourself online from the chipset provider, rather than from the Edimax website.
  14. Instagib
    Instagib Minimodder
    12 Mar 2010
    My system is in a corner of a room and as a result all the PCI cards i tried run into low signal/high drop out rate problems. What i ended up doing was getting a cheap USB adapter and a 5m USB extension cable and put the adapter as high and as away from the walls as possible. It's been brilliant since. Downside is the 5m extension cable snaking up the wall looks naff.
  15. adam_bagpuss
    24 Apr 2009
    buy a PCI or PCI-e card with a detachable aerial or one that has a aerial + lead on it ?
    The abit airpace is one of the best PCI-e ones providing you need G
