Video Working with Glass Hardline Tubing
Discussion in 'Article Discussion' started by Dogbert666, 9 Mar 2018.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    The ultimate hardline tubing material is glass - watch this video to see how to cut and prepare it properly!
    Agamenix likes this.
  2. Cheapskate
    13 May 2007
    Should point out that normal glass will shatter if you heat and let it cool normally. There's always a chance someone will not know.
    Are you using MAP or propane?
  3. Vault-Tec
    30 Aug 2015
    IDK how useful this will be on tubing but many years ago I was a glazier. For about four years.
    The easiest way to cut glass is to cut it, turn it over and tap behind the cut. Maybe you could find a way to do this with tube, as snapping it is pretty cray crazy. I used to love cutting laminate the most. Mostly because you would pour alcohol into the cut and set it on fire :D
Tags: Add Tags
