Scratch Build – In Progress [Worklog] HyperMod - FINISHED! |Vote for it on CM modcontest|
Discussion in 'Project Logs' started by Ch2pa, 30 Aug 2012.
  1. Ch2pa
    Ch2pa What's a Dremel?
    28 Aug 2012
    This week-end it was varnishing time:
    Here is the render of the first coat:
    It was not really dry when I took the picture that's why it shines.
    Next week-end I will apply second coat.
    Second activity of the week-end was to sandpaper and brush the aluminium sheet that I will use for the covers:
    I used an orbital sander first, then hand-sandpapering with 120, 240 and 400 papers.
    The goal was to eliminate this ugly scar:
    After some pass:
    I will show more of it when the covers will be ready ;)
    Last thing that I did this week end was to properly insulate the PCIe riser.
    I tried to use an antistatic bag for the insulation: (thanks G-force for the idea:thumb:)
    It partially worked. I was able to boot and launch a Furmark stress test but the system went down at half of the benchmark.
    So mixed the solutions, using both aluminium foil and antistatic bag with double side adhesive tape.
    I started by placing the double side adhesive tape on the riser: (luckily it's exactly the perfect size! :))
    Then I glued the aluminium foil:
    And finally the antistatic bag:
    The riser is ready for further benchmarks.
    That's all for the week :)
  2. Ch2pa
    28 Aug 2012
    Hello,
    as usual, here is the summary of the week-end's work.
    I finally finished all the cables. Here is a how-to in four steps:
    1-Stripping:
    2-Crimping:
    3-Plug-in:
    4-Result: two 6-pins custom GPU cables!
    This kind of cable is very quick to make: it took me only 30 minutes to do these two.
    Family portrait of all the cables:
    From left to right: 24pins mobo, 4pins CPU, 6pins GPU, Mini-Sata for DVD, Sata for HDD and Sata for SSD.
    I also modded the motherboard slightly by removing the stickers and adding mine:
    Before and after:
    [​IMG][​IMG]
    With the heatsink and SSD mounted:
    See you soon for updates :)
  3. Ch2pa
    28 Aug 2012
    hello all,
    I apologize for the two weeks without updates but I was more busy finishing the mod than posting photos...
    The good reason is that I had to finish the mod before yesterday to be able to join the CoolerMaster Case Mod Competition 2012!
    [​IMG] [​IMG]
    The mod is now FINISHED and I count on you to go on the CoolerMaster facebook page and support my mod ;).
    As a conclusion to this topic, here are the pictures of the final assembly and the final pictures of the mod. Enjoy it:)
    I hope you had as pleasure to follow this mod as I had to make it.
    Thanks to CoolerMaster for organizing this competition which motivate me to do this mod:thumb:
    Thanks for reading.
    Livio likes this.
  4. Pranja
    Pranja Blackwolf
    18 Dec 2011
    This looks great. First class work. :)
  5. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    Love wooden cases! Good luck in the competition!
  6. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    Damn nice work man! The combination of Alu and wood looks really great!
  7. Ch2pa
    28 Aug 2012
    Thanks to all :).
    @Ace_finland: Good luck to you too for the comp :thumb:
  8. Ra6
    Ra6 What's a Dremel?
    4 Nov 2012
    must... not... FAAAAP!!
  9. Cheapskate
    13 May 2007
    Sweeet! I like it. It looks like an old refrigerator with the heatsink on top like that. The fit work is just fantastic. -and really tight in places.:lol:
  10. Ch2pa
    28 Aug 2012
    :D
    Thanks
    Thanks. And you are right, there is not a single centimetre free inside the case (except the one I left for ventilation).
    For those who don't know it yet, this mod is my entry to the CoolerMaster Case Mod Competition 2012.
    I count on you to go on Facebook and vote for my mod ;)
    => https://www.facebook.com/coolermaster/app_275445412567432
    You can win some CoolerMaster stuff by voting!!
    Thanks!
  11. Ch2pa
    28 Aug 2012
