Scratch Build – In Progress Worklog: JP[μ]
Discussion in 'Project Logs' started by JaPeMo, 29 Jan 2016.
  1. storm-83
    storm-83 Minimodder
    7 Nov 2014
    wauw
    looks brilliant! really like the look of the chrome loop together with the black contrast. Keep the updates comming! :thumb:
  2. JaPeMo
    JaPeMo What's a Dremel?
    31 Aug 2013
    Yes, dremel and cut with a little saw.
    Thanks!!!
    Enviado desde mi HTC One mediante Tapatalk
  3. JaPeMo
    31 Aug 2013
    A little update, but a great work to the worklog...
    This piece I spend 3 elbows, It's milimetric piece....The just space...
    What do you prefer, fittings and adapter or pipe? I'm sure witch is my preference :D
    Tomorrow I will go to the built pump and filter support.
    Regards and thanks for your comments!!! :thumb:
  4. JaPeMo
    31 Aug 2013
    Yesterday....
    A little update...
    Today I moddified an Aquacomputer Filter. Above have a G1/8 hole but I changed by G1/4 for insert elbow and valve to drain.
    Before...
    After...
    I corrected a pipe that it is very corved and forced GPU. After I put pump, flow indicator, aquaero and filter. I know how install aquaero, but pump, filter and flow ind, I don't know.
    I don't like that the power supply only you can install with up fan position, maybe I moddify undercase to rotate power supply 180º....
    I think that tomorrow I will found a solution...
    Regards
  5. JaPeMo
    31 Aug 2013
    Today...
    Finally I decided don't install filter by don't charge case in the base and don't disturb aquaero vision.
    I was built plate for pump...
    And finished 2 pipes
    And install Aquaero flow sensor MPS400
    This is all...
  6. JaPeMo
    31 Aug 2013
    Hi!!!
    A little progress. I build holes for fixing HDDs bay
    Yestarday night I look a free space, and I thought, maybe I could install 2x80 fans to force in air....
    And last, I hava a piece of mirror propilene, I was cut and install with double side up the case...
    Now I go to relax. Tomorrow more...
    Regards!!!
  7. JaPeMo
    31 Aug 2013
    Hi!!!
    Today I repeated 2 pipes that was short. After I cleaned and polish, after this DON'T TOUCH WITHOUT GLOVES!!!
    Tomorrow more...
  8. IWantAnA2
    IWantAnA2 What's a Dremel?
    7 Mar 2015
    See, I have kids and phrases like "don't touch this" usually get met with gross little kid finger prints all over it.
    Props for the dedication, it's looking very nice!
  9. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Love the chromed piped! Did you get an entire 12mm cobber tube coil chromed, or did you buy the tube like that?
  10. JaPeMo
    31 Aug 2013
    Buy direct the tube so by the meter. Thanks for your comments!!! :pulgar:
    Regards!!!
  11. JaPeMo
    31 Aug 2013
    Hi subbers!!!!
    I come with 2 updates, paint and restoration of fan and radiator.
    Start!!!
    In first step, I would like paint with chrome paint, I try but I don't like effect and finished. And I decided use spray paint in white aluminum color.
    First with fan. I like it too much, have a gun metal aspect!!!
    Following with rad. I polish and I decided don't paint, Rad have steel in both sides. Polish and paint with clear brilliant lack and with black paint in top and down.
    ESPECTACULAR!!!!! I like combination, following color of my project and inox steel of pump top, mps flow, aquaero and screws.
    This weekeng I have a free time to do other works in my house.
    See you again in a few days!!!
    Este fin de semana tocan otras tareas asi que hasta la semana que viene!!!
  12. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    The grill looks fantastic! Love it! :rock:
  13. JaPeMo
    31 Aug 2013
    THX @Bartacus
    Good, finally stop fitting plug for led arrived to me to install on reservoir...
    And after I draw and cut layer for next acrylic piece build. I hope start wednesday...
    Regards!!!!
  14. JaPeMo
    31 Aug 2013
    Hi
    This post will be longer than normal due to the breakthrough I've achieved. So I hope you enjoy.
    I come with advances these days. I stayed in the last support, because I well, took longer than it should...
    So I had to repeat it. It was a complicated piece by the shape and angles, the slightest mistake could break or burn. Patience was rewarded...
    This piece is to support the aquaero
    Next step, modify front glass. This is joint the box, and don't get front air, so I install a 7mm separators...
    I had gained 1 cm thick for free air intake. However after testing still, fans were able to not take a lot of flow, so I drill rivets and to modify the front of the case by removing all the inner ribs with the dremel, then sanding the surface and finally a layer of paint.
    After this we turn to the lighting, time, testing and wiring, the main problem. Leave well without being burdensome. We start by finishing the lighting side of the box logo
    I leave a video of the tests ...
    I leave the lighting to keep riding hard in the box. SSDs installed with spacers. The idea is to have the minimum wiring seen, already difficult by the large number of cables required Aquaero for accessories and sensors
    And the back after installing everything. I had never gotten such an organization in any of my previous projects, I am satifecho with my result.
    Well, after all this and a weekend muuuuuy intense, it has today arrived FILLING !!!
    The first firing of the RL, only the pump aquaero to test ...
    And after five minutes I had to empty, a board of a male-male adapter tenial very dry board and mashed and lost. So after changing it full again and there he is, on and purging air. Photo and video...
    If all goes well, i am just plug it in, turn on and configure the PC
    In a few days I'll put photos and a final video project.
    Regards!!!
  15. JaPeMo
    31 Aug 2013
    Hi!!
    Today I received a NZXT IU01 for internal USBs wires. Now are installed and case closed.
    In a few days photos and video!!!
  16. Cheapskate
    13 May 2007
    So far everything was great.:D
    I want final pics...
  17. JaPeMo
    31 Aug 2013
    Hi boys
    This case is the hotest case that I was had. Now new modifications....
    This last Friday:
    I want install this shrouds in case...
    Cutting personalized plates in black matt acrilic
    New EK XE 360 rad
    New flow indicator
    Mark to cut
    After cutting
    Midplate to support front rad and fans
    Paint 10 EK Vardar F4 in black matt
    Upper fans...
    inside top grill
    rear guill and fan
    too with front
    And the last, hardware installed
    All done in weekend, but I can't finish in this time, next time more advances....
    Regards!!!
  18. JaPeMo
    31 Aug 2013
    Hi subbers!!!
    This weekend I only build a new support for aquaero. Now I used aluminium with 1mm. Well, afte cut with old layout I drill all rounds....
    And now when it was finished
    Presented inside case...
    After it was paint with black matt sprays with same case tone...
    I mount aquaero and present inside case with all liquid cooling circuit finished.
    Detail...
    Backside of support for all hidden wires...
    This is all at the moment.
    Kind regards!!!
  19. JaPeMo
    31 Aug 2013
    Hi!!!
    Well, this weekend to finish the pc but thought amused me with some improvements.
    First fabricate a cover for the motherboard to plug the rear connectors of the plate. First take measurements and draw in cardboard then cut it and present it on the plate.
    Despues lo pase al aluminio, corte, lime y plegado...
    After you pass the aluminum, cut, lime and folding ...
    And present on the motherboard...
    Then I play the relevant painting session, not take pictures sorry, but mounted on the board you will see in the following photos.
    I made some changes in the RL, I returned to deposit Aquacomputer and I liked a lot more aesthetic that gave the set so manufactures aluminum support also remains hidden behind. You up out photos in the next update.
    After this happens wiring that was not enough, place without plugging in to power but all ordenadito, as God intended. It could be improved as wired but is too big and is another world.
    And finally the RGB LED strips lighting controlled by farbwerk and aquaero
    And this is all that gave the weekend.
    Next week I will have to make a small adjustment because me is impossible to fill the circuit, an air pocket is created and does not enter the liquid. Seran 10 minutes to make 2 holes.
    Regards!!!
