Case Mod - In Progress [WORKLOG] Stilnex
Discussion in 'Project Logs' started by cone696969, 4 Apr 2008.
  1. cone696969
    cone696969 What's a Dremel?
    28 Nov 2007
    Hi, this is my first post, I'm going to remod my old case mod, the mod is:
    [​IMG] [​IMG] [​IMG]
    The mother base would be up the Power supply, and the reservoid will be at back of the case, the radiator will be on the top
    i will do a cover to the power supply and the water bomb, it will be under of dvds rewriters, in the front will be a nokia LCD.
    the color will be black mate.
    Regards cone696969
    Sorry for my english
  2. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    I like to see Nokia LCD's integrated into mods.
    What you have now looks nice, but I would like to see the sides a bit smoother.
    Do you have any sketches of what you want to do?
  3. cone696969
    28 Nov 2007
    Hi Bit Tech
    After a hard weekend I bring news about the mod.
    here the render for the mod, this is only of the front
    [​IMG] [​IMG]
    The first thing of everything was to smooth the front, for it I use putty and sandpaper
    Step 1
    Step 2
    step 3 this time with some of paint to see better all mistakes
    Also one of the wings has been smoothed
    At the end the cover of the front was sanded to paint
    After a few caps of putty and of sanding it touched the front, in which it has put on aluminium and orange UV plexy
    [​IMG] [​IMG]
    the aluminium and the plexy have been turned with the form of the front
    Regards cone696969
  4. Cheapskate
    13 May 2007
    I like it. It would look even cooler if the front orange plexi was a bubble shape.
  5. cone696969
    28 Nov 2007
    After a small paron that tube due to examinations and soon it opens other one for parties XDDD
    So here the advances already!!! 8)
    The utensil that this me extracting of many XD
    Here quite already prepared to start cutting (I extracts the photo when i have cut one)
    [​IMG] [​IMG]
    And here already cut he informs and presented to see if the curve coincides (that it has to since this one extracted of the same sheet)
    [​IMG] [​IMG] [​IMG] [​IMG]
    Here can see the holes realized to fasten the sheets of aluminium and plexy and already also placed in the top of the front to see the effect that gives (it impresses a lot)
    [​IMG] [​IMG]
    After continue with the sheet of support of the motherboard marking and cutting
    [​IMG] [​IMG]
    Regards cone696969
  6. RasmusAnden
    RasmusAnden What's a Dremel?
    28 Feb 2007
    i really like your idea of integrating a small LCD in your mod. :)
  7. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    man that aluminium front looks really cool, great job!!
  8. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Lookin' pretty good so far, can't wait to see more!
