Cooling Worth replacing Corsair H50 fan?
Discussion in 'Hardware' started by SmilerAl, 18 Feb 2011.
  1. SmilerAl
    SmilerAl Terminate with extreme prejudice
    6 May 2010
    In attempt to improve cooling of my CPU, is it worth replacing the standard fan that comes with the H50 radiator and instead using a Gentle Typhoon I have spare?
  2. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Im interested to know this too :)
  3. bladecs_04
    bladecs_04 What's a Dremel?
    5 Jan 2011
    surely if you have one spare try it and post the results you get
  4. SmilerAl
    6 May 2010
    Normally I would just do it straight away but I had a real hard time installing the H50 for the first time, plus I'd have to reapply the thermal paste etc if I was to properly change the fan and that, so I rather ask for the recommendation first beforehand.
  5. chris66
    chris66 Minimodder
    10 Jan 2011
    Surely you do not have to remove the heatsink to replace the fan on the radiator?
  6. bdigital
    10 Aug 2010
    If someone here has previous experiance of doing the same thing, it would be useful to share it.
    I dont have my h50 yet, but i consider this research before i come round to installing it this weekend
  7. Big Elf
    23 Apr 2009
    There's a test of different fans on a H50 here unfortunately not including a GT. Maybe 3-4ºC lower with a GT1850?
  8. bdigital
    10 Aug 2010
    Awesome, thanks for the link.
    I think my approach will be to...
    - Benchmark the system now (with a Freezer Pro)
    - Benchmark the system with the stock H50
    - Depending on the results, decide if i want better cooling.
    - If the answer is yes, il try a Gt 1850rpm
    - If the answer is no, look for ways to reduce noise (maybe turn of a fan and benchmark again)
  9. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
  10. SmilerAl
    6 May 2010
    Hmm judging by the link replacing the fan may drop temps by a few degrees.
  11. markbrett64
    markbrett64 thanks to denial I am now immortal
    12 Jan 2010
    Changing the fan will give you a drop of a few degrees. I have changed mine for a GT1850.
    What case do you have; i.e. where is the current fan situated, is it push or pull etc.?
    Are you having temperature issues?
    As stated above, there is no need to reseat the cooler just to change the fan on the rad.
  12. SmilerAl
    6 May 2010
    HAF 922, the H50 fan is pushing air out whilst two fans at the top are pushing and one on the side is pushing. The large fan in the front is an intake.
    I'm not having temperature issues per say, I'd just like to have cooler temperatures when overclocking and stressing the CPU out.
  13. markbrett64
    12 Jan 2010
    Ok, thanks, I have the HAF 932, so a similar setup, so something like a GT1850 should drop a few degrees for you.
  14. jrs77
    jrs77 Modder
    17 Feb 2006
    Let the fan draw air in from the back and use the two top-fans to get instantly rid of the warm air. Your temps will see another 3° improvement instantly. Oh... and mount the fan to pull air through the rad instead of pushing and you'll get another 2°.
    I'm using a H50 with a stock-fan PWM-controlled sucking air in a SUGO 05 and my i5-760 @ stockspeed get's up to only some 60°C when running Prime95 for some 20 minutes, while the fan speeds up to some 1700RPM.
  15. donok
    donok Every Little Helps .....
    16 Feb 2011
    what about silverstone air penetrators
  16. SmilerAl
    6 May 2010
    After taking out the fan, replacing it with a Gentle Typhoon positioned to intake air now the temps have dropped around 15-20 degrees whilst using Prime 95!
    Now after leaving Prime on for more than 10 minutes the temps haven't even got to 80 degrees unlike earlier when they were almost hitting 95+!
  17. SmilerAl
    6 May 2010
    Should also mention I'm running an i7 920 overclocked @ 4Ghz (if you don't read my signature).
  18. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    ive been doing quite a bit of research on the h50 the last few weeks as im planning on mounting one on my fiancees 2500k. from all the reviews ive seen, replacing the stock fan on the h50 gave a boost to cooling performance. it would seem the stock fan isnt the best.
    i have a 150cfm PWM delta that will be going on the h50 when it gets here tuesday. it will run at low speeds most of the time, but ill do a few 4,000rpm full speed p95 passes for you guys and let you know how it goes!
  19. SmilerAl
    6 May 2010
    This is true, the blades are spaced out and don't feel that good. The only good thing I suppose is the cable is nicely braided (unlike mine).
  20. heir flick
    heir flick Minimodder
    2 Feb 2007
    I replaced my stock fan with 2 apache in push pull, cooler and less noise
