Windows Would it do it?
Discussion in 'Gaming' started by EX3CUT1ON, 25 Jul 2008.
  1. EX3CUT1ON
    EX3CUT1ON What's a Dremel?
    17 Jan 2008
    Would someone be able to tell me if the following system would be able to run Crysis at 1920x1200 with all it's settings maxed out with the FPS never hitting lower than 60?
    Vista Ultimate 64Bit
    Intel Core 2 Extreme QX9770
    EVGA 790i Ultra
    X3 EVGA GeForce GTX 280 Cheesecake in TRI-SLI
    X4 Mushkin Ascent XP3-12800 2GB
    Would this system be able to do it? Thanks.
  2. Kierax
    Kierax What's a Dremel?
    5 Mar 2008
    Hmmm I'm yet to see anything run Crysis at that resolution on max with anything about 40 constantly. But those are killer specifications.
  3. Krikkit
    21 Jan 2003
    The only thing I'd question is the RAM - you might be better with 4GB. :)
  4. EX3CUT1ON
    17 Jan 2008
    There's a article on this site that says that Crysis benefits from having 8GB, so what makes you say that?
  5. Kierax
    5 Mar 2008
    The more ram the better and if he is building a system like that, then I see little reason to leave out a few slots :D
  6. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    I think he's not noticed the x4 at the start of the line. Just reading the 2gb. To be fair though. Hardware names are so stupid nowadays it's an easy mistake to make :p
    Anyhoo, that system will have no trouble if you play it on a small res (1024x768) or a HDTV but you'd be pushing it at a big resolution monitor.
    Also, Crysis still looks awesome running at about 20fps. It uses blur very effectively. Tricking the eyes into seeing smooth motion even if it's not. So while it might be nice if it ran at 60fps, you'd be just as happy at 30.
  7. EX3CUT1ON
    17 Jan 2008
    My mistake. What if you did a sustainable overclock of every thing?
  8. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    :eyebrow:
    HDTVs go up to 1920x1080, that's not exactly small >.>
    I'd get 2x 4Gbs dual channel instead of 4x 2gbs
  9. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    I'd think the cpu would be the bottleneck in that unit, i understand it's an amazing cpu but with 3x gpu's and that much ram. Get a skulltrail with 2x cpu and 2 GTX 280's in SLI with 8 / 16 GB of ram and a solid state drive for speed and then you'll be like ZOOM!
  10. Krikkit
    21 Jan 2003
    Sorry, that'll teach me to concentrate harder on the OP.
    You'd be better off with 2*4GB sticks rather than 4*2GB sticks. :D
  11. DarkLord7854
    22 Jun 2005
    And some Mountain Dew :p
  12. EX3CUT1ON
    17 Jan 2008
    Where can I get two modules of DDR3 4GB RAM?
  13. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I don't think they're available in the UK yet? I've certainly never seen 8GB (2x 4GB) kits anywhere at least?
    So just stick with yer 4x 2GB modules ;)
  14. EX3CUT1ON
    17 Jan 2008
    So you think it would be better with the Intel D5400XS (Skulltrail) even though it would have one less EVGA GTX 280 Cheesecake and it doesn't support DDR2 or DDR3. Would Crysis recognise the four extra cores though?
  15. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    I hope your not actually thinking of buying all this just to run Crysis at 60fps? :eek:
  16. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    all this for a £40 game. bragging rights are stupid.
  17. Jordan Wise
    Jordan Wise Baby called to see the boss...
    24 Jul 2007
  18. Akava
    Akava Lurking...
    28 Jul 2007
    +1
    Interesting to see what it does though I guess.
  19. ShredMachine
    ShredMachine What's a Dremel?
    29 Feb 2008
    Agreed. From what I understand its not even that amazing a game. Hell, I'm running TF2 just fine on a 6800GS and a 3700+, and I don't see anything wrong with that BECAUSE THE GAME OWNS.
  20. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    crysis really isn't worth spending about £2000 on pc equipment to play, its boring and generic. makes great screenshots and in game movies with fraps but id just cry if i built that pc and then realised that was what id done it for.
