Case Mod - Complete ⭐ Wrynn ( Sponsored )
Discussion in 'Project Logs' started by Forsberg Customs, 16 Oct 2019.
  1. Forsberg Customs
    Forsberg Customs Minimodder
    9 Jan 2018
    Hi everyone!
    It´s time once again to start a new project and this time i will do a case mod on the Corsair 280X. The theme for this build will be a Warcraft, specifically the Alliance. The name Wrynn comes from the human king with the same name and the build will heavily be infuenced by their city Stormwind.
    Most of the parts for this build has been modeled by me and then 3d-printed. The whole build will later be hand painted aswell.
    The parts i will be using for the project is,
    Chassi: Corsair 280X
    Motherboard: Asus Crosshair VII Impact ( Sponsored by Asus )
    CPU: AMD 3700X
    Memory: Corsair Vengeance PRO RGB 2x8gb 3200mhz ( Sponsored by Corsair )
    SSD: Corsair MP510 240gb ( Sponsored by Corsair )
    GPU: Asus Strix RX 5700 XT ( Sponsored by Asus )
    PSU: Corsair RM650 ( Sponsored by Corsair )
    Cooler(s): Corsair H100i Platinum ( Sponsored by Corsair )
    The build is sponsored by Asus and Corsair so a big thanks to you guys for helping out with this project! Here are the components that they provided
    Lets start with the case which is the Corsair 280X
    Here we see the top of the case which i've started to measure up for the "planks" that will go on top
    Took a trip to the lumber yard!
    Organized chaos of planks before assembly
    First run of the planks glued in place
    The middle part of the top is at an angle so it's going to be a little tricky
    "MORE PLANKS!" i yelled to the computer and it listened, sliceat and done!
    The top done, time to move on to the front
    The start of whats going to be a room in the castle wall
    The start of the top ledge of the wall
    Lower ledge and the backplate in place
    First part of the wall in place
    And a corner
    First part which really indicates the theme, FOR THE ALLIANCE!
    The front bars bellow the logo is supposed to look like the dungeons inside the walls of Stormwind
    Time for some more walls and bars for the right side panel
    1/4 of the panels for the right side panel done
    Half way!
    There we go! the right side done
    The same type of bars here since the vents for the PSU is right behind it
    Lets start with the other side
    The left side panel here with it's panels attached
    Mounted on the case
    Another angle, turned out quite well imo
    Did we forget a side? Ooh yea the backside of the case, more walls!
    Lower half done
    Everything printed, time to glue
    Holder for a sign complete with a magnet
  2. Forsberg Customs
    9 Jan 2018
    The holder you saw in the last picture will hold a "tavern-sign" with my logo on it that will be detachable for transit when i go to events like Dreamhack and here it is in pieces
    Starting with the base of the sign
    Logo next
    Tried to 3d-print a chain for it but it turned out quite bad which a good friend of mine @timpelay kindly pointed out ;) this will be adressed in the future
    The beam which holds the sign
    Mounted with the ugly chain ;)
    Magnet attached, will it work ?
    It did! :D
    The power-button must get some love aswell
    Starting to make a piece that can reach down to press the original button
    And then a frame that goes around that to keep it in place
    And finally a button with WoW's logo on it
    In the middle of everything i decided my printer needed a home. The blueprints for this enclosure can be found here https://www.thingiverse.com/thing:2864118
    Welcome home! :D
    Here we have the "room" for the front panel which i showed you in an earlier picture
    Complete with chairs, a table, dishes, pints and ofc cheesehttps://imgur.com/pOjp386.png[/IMG]
    Time for some painting, this needs to be done now since it's going to be impossible to do it when its mounted
    Starting with a black base which i can recommend if you are going for a stone or metal look
    Painted Corsairs logo yellow the using a spunge with differend shades of grey, white, brown and black i made the rest look like stone
    Accessories for the "doll house" painted
    Glued in place
    You have to put in some goodies in these types of builds and this time it's the legendary sword Ashbringer
    It will get a place of honor in the other room where Asus logo is
    Ashbringer, barrel and holder for the sign painted. Note that i also switched out the chain for some real one instead of the 3d-printed one, happy now @timpelay ? ;D
    Room painted and everything is in it's place
  3. Forsberg Customs
    9 Jan 2018
    I decided to mod the cooler aswell and give it a fiting look for the theme. I modeled a sleeve for the pump that slides over it and utilize the built in lights for the alliance logo
    Comes in two parts to ensure the best quality without supports
    Mounted but not painted, ill fix that!
    Took the dremel and made some gashes and bumps in it since stone is not uniform
    Basecoat of black, time for some grey's
    The best thing about using black as a base is that all of the lowspots will come through nicely with the grey paint on top
    A good coat of grey has been applied, time to make it dirty and weather it
    The weathering as begun
    There we go, time for some lights
    As i said im using the built in lights on the pump/block for the logo lights and ive used a thin sheet of polystyren as a diffuser and it works quite nice
    Lets switch to the right color, blue!
    The light on the side leaks out to give it a sublte effect around it aswell
    Giving my motherboard a fiting make-up aswell
    Let's start by installing the cpu
    Installing the ssd in the dimm.2 adapter that comes with the motherboard
    This panel can be removed from the motherboard by removing two screws
    There we go
    Two panels for the motherboard straight from the printer
    They will be attached like so
    After they have been painted and it sort of looks like powdered candy ( dont eat them )
    The soundcard have a little plate that will get a nice treatment aswell
    Poof!
    Starting to mask of the part thats going to be "metal"
    The other parts get a "stone-effekt" applied
    After that i go over some of the other parts to give it a torn look
    Panel attached with a distressed look aswell
    Same for the other one
    After some weathering
    Done!
  4. Forsberg Customs
    9 Jan 2018
    Time to fix the chain and paint this! ( A big thanks to my girlfriend for helping be with some painting )
    Chain bought at Panduro
    A little piece done
    BAM! there we go, what do you think ? It's going to get the weathered and distressed look aswell before it's done
    Time to start making the stones on the walls look less like Legos and more like stones
    A Dremel with a grind bit works well for this
    Half the front done
    There we go, then it's just the whole other case to do :(
    Here we have the floor for the main chamber in the case which is inspired by the floor inside Stormwind keep
    Rombs!
    Test fit and it seems to fit, time for paint
    This was all i hade for now but more will come so stay tuned. If you want the latest updates and some otherwise nerdy content you can check out my Instagram @forsbergcustoms
    Until next time friends!
    MLyons, arduum and Cheapskate like this.
  5. Cheapskate
    13 May 2007
    That's a tidy cladding job. :thumb: Whoever painted the wood did a fantastic job, too.
  6. arduum
    arduum Minimodder
    10 Mar 2015
    amazing:rock:
  7. Forsberg Customs
    9 Jan 2018
    Well thank you sir! :)
    Thanks Cheaps :) Yea the wood turned out real nice :)
    Thanks! :D
  8. storm-83
    storm-83 Minimodder
    7 Nov 2014
    i like that i modded the motherboard to make it fit in with the theme!
    the whole theme and work is great
  9. delevic
    delevic What's a Dremel?
    21 Feb 2015
    Nice job!
  10. Forsberg Customs
    9 Jan 2018
    Thanks dude! Yea they're subtle mods but i think it will look cool in the build :D
    Well thanks :D
  11. timpelay
    timpelay What's a Dremel?
    18 Jun 2015
    Now I'm satisfied ;)
  12. Forsberg Customs
    9 Jan 2018
  13. Forsberg Customs
    9 Jan 2018
    Update!
    So since last time a couple of things have happend. I hope you like it and feel free to leave a comment :)
  14. Forsberg Customs
    9 Jan 2018
  15. Forsberg Customs
    9 Jan 2018
    Thanks bro! :D
  16. Forsberg Customs
    9 Jan 2018
    Update! So a couple of things have happend since the last update. The biggest thing is that me and my partner have become parents which explains the lack of updates :). Besides that ill let the pictures do the talking. Feel free to comment and tell me what you think about it. The graphicscard should coming in early next week so stay tuned :D.
    Until we speak again, cya!
  17. Forsberg Customs
    9 Jan 2018
  18. Forsberg Customs
    9 Jan 2018
  19. storm-83
    storm-83 Minimodder
    7 Nov 2014
    the rgb on the ram and fans are an eyesore - to me...
    you did such good work with everything else and kept the theme together well
  20. Cheapskate
    13 May 2007
    OK, You might want to scale back some of the less important pictures. :lol: It was like I was back in the dialup era, then Chrome crashed. What little I saw was awesome.
    wolfticket likes this.
