Xbox 360 xbox 360 spec
Discussion in 'Gaming' started by herbs, 9 Dec 2007.
  1. herbs
    herbs Nobody but us chickens
    7 May 2001
    Do any of the xbox's in the shops come with vga? or are they hdmi only? or better still both ports. Or if someone can provide me a link of the different model specs I could look it up myself.
  2. DougEdey
    5 Jul 2005
    All now come with HDMI (well, the newer production ones). VGA is available via a cable for between £10 and £15
  3. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Get the official VGA cable - worth extra couple of quid.
  4. Guest-16
    Guest-16 Guest
    Much agreed - better quality and you get optical out too.
  5. herbs
    7 May 2001
    thanks for the info.
  6. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    The official MS VGA cable is the way to go. I have one to run at 1080P on my HD TV and is superb.
    But the new 360's come with HDMI so if you got one of those then its worth using that instead even if your not using it on a HD TV.
    If your using it on a monitor which has a DVI port then use a HDMI to DVI cable and your sorted like this one I use for my PC.
    http://www.play.com/Electronics/Ele...XtremeHD-2M-HDMI-To-DVI-Cable-EU/Product.html
    EDIT: Also, dont forget that if you are buying a new Xbox 360 then you might be interested in the new recomend a friend sceme this chrisatmas which MS will give you and your friend 10 xbox live arcade games for free!!!!!!
