Motherboards XFX nForce vrs EVGA nForce
Discussion in 'Hardware' started by vega_moo, 10 May 2012.
  1. vega_moo
    vega_moo What's a Dremel?
    9 May 2012
    Hi, Could anyone tell me, I had a EVGA NFORCE 680i SLI SOCKET 775 MOTHERBOARD which sadley blew up.
    Im thinking of getting a XFX NFORCE 680i SLI SOCKET 775 MOTHERBOARD as a replacement, as i want to try a different manufacturer.
    Are they compatible? Will a XFX board work in place of a EVGA board? Will it work with all my other components?
    Also, is this a good idea? Is the XFX ok? (my evga board blew a load of capacitors and someone told me this is quite common for these boards so i want to try and avoid getting another if i can)
    Thanks!
  2. Fire Strike
    Fire Strike What's a Dremel?
    27 May 2010
    As far as i am aware the XFX boards are exactly the same as the EVGA boards. When I had my nForce 780i from XFX it was just a Nvidia reference board with XFX logos and branding on it, so i'm guessing its the same for the 680i.
    And yes, everything will work fine, just unistall the existing Nvidia/EVGA drivers and reinstall them from the Nvidia/XFX website.
  3. Guest-16
    Guest-16 Guest
    They were both made by Foxconn or Flextronics afaik, only the BIOS varied a bit. They weren't the best quality at the time (2007/8).
  4. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Honestly I'd use this is a good excuse to get as far away from nForce as possible and change/update sockets and motherboard.
  5. The_Crapman
    5 Dec 2011
    I can recommend asus boards very highly. Get yourself a striker II nse or extreme as they're nforce 790 boards so a bit more recet. You'll need to do a repair of windows after installing it and I'd recommend flashing it to the 1402 bios.
    However, this might just be the time to ditch the aging 775 and get sandybridge.
  6. The_Crapman
    5 Dec 2011
  7. Guest-44432
    Guest-44432 Guest
    My Asus Rampage has Foxconn components all over it. So I hope the quality is better now! :)
  8. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    The boards were not ordered built to the best spec, and many of them failed because of it. Foxconn can make it great, or they can make trash, it's what the person buying pays for.
  9. nuc13ar
    nuc13ar What's a Dremel?
    5 Jul 2010
    i own one (was two, but the store allowed me to return one). do a search for "tigerdirect" and "XFX 680i"
  10. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Asides from the heat issues which I've now resolved with water cooling and a little capacitor squeal, my EVGA 680i is a top board and the first true enthusiast chipset I worked with all those years ago. If you get enough posts and live in the UK I think there is a 680i board available from the Bit-Tech marketplace for not much. You could certainly move to a cooler chipset but if you're looking for a straight transfer the 680i can be tamed with a little effort!
  11. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    He will need new ram with a 790
    But yeah I'd sell your old stuff and move on, leave 775 behind if you can
    Not trying to shamelessly self promote here, but just so you know I will be throwing up and i7 965 with rampage 3 extreme system later for a good price
    Sent from my HTC Sensation XE with Beats Audio using Tapatalk 2
  12. Guest-16
    Guest-16 Guest
    Everyone uses Foxconn components, like rear I/O or sockets, because they are an industry standard, but actual manufacturing is another thing altogether: PCB quality, QA, capacitor choice, board design etc.
