Electronics Xmas tree bulb question
Discussion in 'Modding' started by Goreblast, 19 Nov 2007.
  1. Goreblast
    Goreblast What's a Dremel?
    6 Apr 2004
    I know its nothing to do with Computers but I figure someone here should be able to answer this question.
    I have a set of lights which uses screw-in bulb rated at 3.5V 0.5W. They are long since discontinued. The nearest match I can find are ones rated 3.6V 0.47W. I presume the bulbs will be OK for voltage as they will be getting 0.1V less juice than rated, but slightly over-Watted.
    Any ideas?
  2. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    they should be fine. they may get a little hot though. but with such a small over wattage it shouldnt make that much of a difference. just replace the bulbs, and plug them and leave them within reach for a while so you can check on how hot they get
  3. desertstalker
    desertstalker What's a Dremel?
    7 Feb 2004
    They will not be "over-watted" the rating on a bulb shows how much power they will USE at the specified voltage, if you supply the bulb with 3.6V it will draw 0.131A (total 0.47W) so supplying it with 3.5V it will draw 0.126A and only use 0.44W.
    They should be fine but perhaps a bit dimmer.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    A problem could arise if different wattages are mixed in the series string. The higher wattage bulbs will have a lower resistance and drop less volts, throwing more of the supply across the low wattage bulbs in the string.
    However, the difference here is so slight I'd say they were equivalents.
