With my initial installation I relocated "My Documents" folder to another partition (in hopes that if I had to reload/format C:\ I wouldnt lose anything. Well I recently overhaulded my system with upgrades and was forced to re-install. In doing so, I now get ACCESS DENIED!!! on "My Documents" folder. I cant delete it, rename it, copy, move, or FORMAT the partition. Well I went to use a boot disk, hehe and cant even see the NTFS file partitions... Its bad enough I lost it all, but I am really pissed I cant get rid of it. Anyone have a suggestion other than re-partitioning my hard drive to remove this file???
dude i got u answer ok when u formated u deleted the sam file that decttates the usage of all files and this leves a tage in every file on the dh when u reformat it dosent matter if u do it exactly the same or not the sam number changes but u can get the files back. right click and go to properties and select take ownership of...but u have to be loged in as the system admin then the files are implomented with your sam munber and u can have them back :rofl:
