XP cooler...question...
Discussion in 'Hardware' started by lowtech, 21 Nov 2001.
  1. lowtech
    lowtech What's a Dremel?
    24 Oct 2001
    please recommend a HSF for this processor...i want quite but effective cooler...
    thanks...
  2. Will
    Will Beware the judderman...
    16 Jun 2001
    Well looking at your current setup, I dont think money is a problem for you :D I would recommend either a Vapochill (basically a freon cooler for the cpu, works like a fridge element and gives load temps of -8 ish) for the ultimate in cooling (£600) but more realistically the Alpha PAL0485 thing with a papst or panaflo 80mm fan (about £40 for heatsink + 19 for fan)
  3. lowtech
    24 Oct 2001
    where can i get these HSF?
    ive looked in oveclockingstore and tekheads i cant find it.
  4. Chrisy
    Chrisy What's a Dremel?
    27 Jul 2001
    Chillblast.com is your best bet. Thats where I got mine from.
    Chrisy
  5. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    id reccomend the zalman flower heatsink if youre going with air cooling. it has the highest surface area of any heatsink out there, and plus it just looks spiffy!
  6. Evilbob
    Evilbob What's a Dremel?
    28 Apr 2001
    Id reccomend an Alpha PAL0485 or a Swiftech MC462-BA both very nice expensive coolers, but if ur looking for something cheep and cheerful that'll do the job id get a Taisol 760
  7. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Whilst I'd recommend the PAL8045 as well, unfortunately it won't fit on the Tyan Tiger. It is an HOOJ heatsink.
    With what will fit, for not too much money, I'd go for something like the new Globalwin SAK38, and then change the fan for something bearable (I gave up with the FOP38 in the end).
