Build Advice Yet another build advice thread
Discussion in 'Hardware' started by Dreamcometru, 27 Oct 2021.
  1. Dreamcometru
    Dreamcometru Minimodder
    11 May 2009
    Hi could you please help me on a build for Xmas
    I was hoping for something along the lines of
    https://www.scan.co.uk/wishlists/29d9c143-d342-4497-aef5-be7dfe169c86
    can you tell me if this build is gonna be ok for modern gaming?
    also what’s up with the 3 pin led connectors for the mobo? - I’ve never seen these before
    subsequently, will I be ok with that psu or will I need another? It doesn’t have any 3 pin connectors u see…will I need additional cables?
    Will be playing nothing too heavy. maybe
    Some dota2 and for honour etc
    thanks in advance guys and gals!
  2. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
  3. Dreamcometru
    11 May 2009
    Thanks I missed that :)
  4. Dreamcometru
    11 May 2009
    Can anyone help with this post please?
  5. sandys
    sandys Multimodder
    26 Mar 2006
    It will be fine for low end gaming on the simpler titles you mention.
    As mentioned above faster ram would be beneficial particularly as you are using system RAM for Graphics, if you can stretch to 3600 CL16 it would be ideal,
    what's the fan guard about?
  6. Dreamcometru
    11 May 2009
    The dust filter?
  7. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
