Case Mod - In Progress Yet Another WC'ed Lian Li..
Discussion in 'Project Logs' started by AlexB, 6 Oct 2009.
  1. AlexB
    AlexB Web Nerd
    22 Dec 2005
    Ok, so I think I'm addicted to these things. As you may have seen from all of my previous builds, I am a bit of a Lian Li fan.
    Anyway, I impuse-bought a little lian-li off a chap on here, and it wasnt even going to be water cooled - just wanted the case.
    I then got him to do me a deal on a rad along with the case, to do a dirt cheap WC install..
    Then I bought a new graphics card, and a motherboard, and doubled my ram, then bought a new res+pump, and a new hard drive..
    So, from start to finish (in literally a few hours):
    Start with a pile of bits:
    Start to work out how it's going to fit in..
    Panic a bit about the lack of space..
    Go for it anyway ;)
    Get the loop in place..
    Fill it up, test, and fit everything else.
    Hard to get a clear pic of the lack of wires as everything is black.
    so, now it's sat under my desk purring away. I don't have a fan controller anymore, so the fans are a bit loud, but the temps are very low and I'm fairly happy with the air flow, for now.
    I'll get some more pics later with the side on (which has a tinted window).
    Cheers for looking.
    a
    Burnout21 likes this.
  2. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    dont know why there are so many A05's recently but they are dam nice!
    surprised the 4870X2 fits!
    rep!
  3. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    There is so many a05's good thing we all like looking at them SFF is the new "in" thing it seems. good thing i love em.
  4. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Yummy.
  5. Pazu
    Pazu What's a Dremel?
    10 Aug 2005
    Props for having the A05! Nice to see you take the plunge to put everything inside, it's a very tight squeeze indeed. :)
    Subscribed!
  6. AlexB
    AlexB Web Nerd
    22 Dec 2005
    Quick update.
    My fans were too loud, so I ordered a couple of fan controllers. They were horrid silver.
    So, I decided to mount them in my case.. pics show the process :)
    (notice the silver bits where I managed to ruin the case a bit.. sigh)
    Not bad little units, heat sinks and everything..
    -al
  7. jhanlon303
    7 Sep 2006
    Can a case that supports a full ATX motherboards and all this coolness really be called SFF?
    I like it.
    john
  8. 500mph
    22 Jun 2007
    Looks good, but where are the 8 fans? Or are some of the controllers not used.
  9. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    one more A05 mod!
    good job!
  10. AlexB
    AlexB Web Nerd
    22 Dec 2005
    Only got 6 fans - top, rear, 2 on rad, front, and southbridge. :)
    Cheers for the comments.
