Displays Yuraku 24" for £155, should I get one?
Discussion in 'Hardware' started by Ending Credits, 1 Jan 2009.
  1. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    Press Menu and + at the same time, you'll go to a hidden menu with your panel info. Props to Kenco_uk for finding that out.
    You'll see the panel part number, and you can google that for more info.
  2. kenco_uk
    28 Nov 2003
    I've taped over the unecessarily bright blue power led to tone it down :)
  3. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    It's a SA-LTM240M2-LO1 panel. So one of the good ones.
    Cupboard likes this.
  4. Sir Digby
    Sir Digby The Supprising Adventures
    18 Jan 2009
    Looks like a great deal, could I get 3 short questions answered please? Before I take the plunge and buy one :hehe:
    • Is it HDCP? - the specs don't seem very clear on this...
    • How does 1080p stuff look on it?
    • And is there any way of knowing what panel I'm getting before buying it?
    Cheers
  5. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Yes
    I haven't got one
    No
  6. Ending Credits
    4 Jan 2008
    1080p stuff looks OK, it's not ideal but my Xbox looks fine on it.
    And no, there's no way of telling what panel you're getting before you buy (it shouldn't matter too much as long as it not a TN one which I'm not sure if any of them ship with.)
  7. DougEdey
    5 Jul 2005
    The HDMI cable should carry the audio, does the monitor have an audio source option of HDMI?
  8. Sir Digby
    18 Jan 2009
    Ok, thanks for the help - looks like I'm getting me a nice big screen then :D
    I guess I can always return it if the panel isn't any good...
  9. Ending Credits
    4 Jan 2008
    It's an HDMI cable to DVI. I just "modded" the Xbox component cable so it would fit next to the DVI cable. The monitor comes with a component -> 3.5mm jack converter.
  10. DougEdey
    5 Jul 2005
    In that case, you should just take the component 360 lead and crack the casing off, that'll let you stick it into the 360 at the same time as the HDMI with no issue
  11. mooseguy
    mooseguy Crazy Moose
    17 Oct 2008
    I've just ordered one from Aria for £160, the offer came back. There's still three left at that price if anyone else is interested :)
    Here's to hoping it's a VA panel. Hopefully, looking at EndingCredit's experience, it will be. Even if it isn't though, it's still a lot of monitor for the money.
  12. Sir Digby
    18 Jan 2009
    Well, I got it ordered so bring on Saturday :thumb:
  13. mooseguy
    17 Oct 2008
    Mine arrived! It's a VA panel, code CMO-M240J1-LO2. First impressions: big, bright power light, nice colours.
  14. Xtrafresh
    27 Dec 2007
    i am soooo tempted to buy two more of these for triplescreen goodness... 320+ shipping is laughable for such an extreme setup! :eeek:
    Should i? Should i? *hovers over the 'buy now' button*
  15. Sir Digby
    18 Jan 2009
    Do it! You'll only be doing your part to stimulate the economy! :hehe:
  16. kenco_uk
    28 Nov 2003
    Do it, post pics and have cheesecake.
  17. Ending Credits
    4 Jan 2008
    I'm tempted to buy another myself but I'm as broke as my "k" key (i.e 'I thinw my w wey is browen') .
  18. mooseguy
    17 Oct 2008
    I'd like another one - they're awesome. Problem is that I can only fit one of these and a 19" at most on my desk. :sigh:
  19. DougEdey
    5 Jul 2005
    I have a bright power light on my TFT too, I used insulation tape to "remove" it
  20. kenco_uk
    28 Nov 2003
    Finally got round to putting the other bit of my arm in and now realise I've got to shift where it's mounted to the desk as I prefer having it a little bit further back!
