Hi all, my Zalman HD cooler just arrived Clickey But just opened up my case and remembered my cd bays are tool free design. Instead of threading a screw through, theres a slider bar with pincers that go into the drives side holes. Holds my drives in perfectly, but not sure about the compatability with the HD cooler as its 4 pipes from the main frame (see the pic) that screw into the case and no full contact for a proper fit like with a cd drive. Im worried that because they are not screwed in that vibrations will be an issue, its not with my CD drives as they fill the bay. Anybody know if it will work ok, saves me bursting open the packaging. Thanks.
I have a tool free case too. With A litle bit of push you can take the tool free machanism off and just use the screw holes.
