Hardware Zalman Reserator 3 Max Review
Discussion in 'Article Discussion' started by Meanmotion, 21 Oct 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. douglatins
    douglatins What's a Dremel?
    28 Nov 2009
    Still with those circular tubes, damn it, use slim and long rectangular one geez
  3. Panos
    Panos Minimodder
    18 Oct 2006
    Corsair H100 in push-pull config with 3rd party high airflow, low noise fans cannot be beaten imho but from a dedicated water cooling solution that uses 480 size radiator.
    I have it on my system and the FX8350@5Ghz runs pretty cool even under full load benching.
  4. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Haha well that was a good one, set me up for the afternoon. H100 better than a custom loop unless with 480mm of radiator...
  5. GeorgeK
    18 Sep 2010
    Disappointing really - it would be nice to see someone seriously challenge the Corsair H series. The main downfall in my opinion with this is that you can't switch out the fan for better / quieter ones...
  6. Panos
    Panos Minimodder
    18 Oct 2006
    @ £44.50 the H100 was going for, at OC UK three weeks ago when I bought it? Yes. Even at £70 is far better value for money solution to water cool your CPU only.
  7. Maki role
    9 Jan 2012
    I don't think watercooling should ever really be used within the context of value for money. Pure performance wise, an H100 cannot compete with a proper water cooling setup. As for value, sure it wins there, but you never stated value at all in your comment. Normally I wouldn't be pedantic about this, but leaving out that part radically changes the meaning of the entire comment.
  8. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    I think your missing the point...
  9. rollo
    rollo Modder
    16 May 2008
    in the All in one Water cooling world the H100 with custom fans is a tough competitior for any of these other brands.
    Its not competition for any real water cooler setup. Unless your competeting on price in which case your not really after a full blown water cooling setup anyway.
  10. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Titan Fenrir Cheesecake :D
  11. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    h100 is still available at ocuk and scan at just over 40 quid (scan being a quid or 2 cheaper)
  12. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    So... Still no AMD test setup? It might look a bit mental but they are still some among us that use AMD (I'm one of them).
    Kind of looking forward for this product, not sure how should I feel since I was hoping it would be very good.
  13. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Are the refurbished models worth the risk though?
  14. hero1
    hero1 Minimodder
    18 Oct 2013
    I hope no one wastes their money on this thing, especially up here in North America. I am disappointed by its performance.
  15. Panos
    Panos Minimodder
    18 Oct 2006
    I bought mine and was sealed like brand new. Installed 2 more fans and holds the FX8350 @ 5Ghz.
    My H50 was refurbished also which I bought back in 2010, and still working on my mates PC now.
  16. Unicorn
    25 Jul 2006
    One of my i7 rigs runs on a third hand H100. There's nothing you can do to them short of being a ham fisted idiot and physically breaking them which would impede their performance or reliability.
Tags: Add Tags
