Case Mod - Complete ZOROG II
Discussion in 'Project Logs' started by neSSa, 16 Sep 2020.
  1. neSSa
    neSSa Multimodder
    11 Aug 2014
    Hello guys,
    this is not a classic case-mode, I will make changes to one of my favorite projects "ZOROG" which will still find a place on my desk in the form of a computer for entertainment.
    I will totally change the inside and outside of the case, using the same hardware with some minor updates. And this time I thank all the companies that supported my work!
    On the 3D renders below you can see an idea of what it will look like:
    Thank you for watching!
    BR, neSSa :)
  2. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
  3. neSSa
    neSSa Multimodder
    11 Aug 2014
    This time I go with RGB fans on a 420 radiator, in a PP configuration :)
  4. neSSa
    neSSa Multimodder
    11 Aug 2014
    Work on aluminum and acrylic parts.
  5. Karrek
    Karrek Minimodder
    7 Jun 2011
    Good stuff, I'm interested to see it come to life. Is this in your home workshop? How much cleanup on the edges is there after using a CNC? And what kind of metal brake do you have access to? (I've been debating if I should get one, or even build one myself...)
    neSSa likes this.
  6. neSSa
    neSSa Multimodder
    11 Aug 2014
    Thanks, yes this is my workshop, but the aluminum was cut on a Laser CNC utility at my friend's. There are not many chips on the edges, but they need to be cleaned and the metal prepared for powder coating.
  7. neSSa
    neSSa Multimodder
    11 Aug 2014
    The parts are easily prepared for assembly
    Cheapskate and Jean R built like this.
  8. neSSa
    neSSa Multimodder
    11 Aug 2014
    Last piece for this puzzle has arrived! Mighty and beautiful, EKWB Magnitude TR edition ❤️
    lowfat likes this.
  9. neSSa
    neSSa Multimodder
    11 Aug 2014
    Start re-assembling :)
    lowfat likes this.
  10. neSSa
    neSSa Multimodder
    11 Aug 2014
    Progress...
  11. neSSa
    neSSa Multimodder
    11 Aug 2014
    Changing CPU block to beautiful Magnitude and prepare hardware to install :)
  12. Cheapskate
    13 May 2007
    I like the metal inlays. I think most of us are programmed to 'metal panel, plastic inlaid window' instead. The change up makes it stick out.
    neSSa likes this.
  13. neSSa
    neSSa Multimodder
    11 Aug 2014
    I had to take a coffee break :)
  14. neSSa
    neSSa Multimodder
    11 Aug 2014
    Some minor fixes, but in the end the hardware is in the right place...
    censored_Prometheus_ likes this.
  15. neSSa
    neSSa Multimodder
    11 Aug 2014
    Preparation for pipe routing ..
    lowfat and censored_Prometheus_ like this.
  16. neSSa
    neSSa Multimodder
    11 Aug 2014
    A bit of cabling, great EKWB EK-Loop connect and XPG Prime A-Rgb strips :)
  17. neSSa
    neSSa Multimodder
    11 Aug 2014
    Almost done!
  18. neSSa
    neSSa Multimodder
    11 Aug 2014
    Video worklog, part 1 :)
  19. neSSa
    neSSa Multimodder
    11 Aug 2014
    Video worklog part 2, is UP, project is finished, final video and photos soon :)
    Video:
  20. neSSa
    neSSa Multimodder
    11 Aug 2014
    Tomorrow at 15h, the final photos and the video for "ZOROG II" will be posted. Here's a teaser photo for now
