Hardware Zotac Z68 Mini-ITX WiFi Review
Discussion in 'Article Discussion' started by Baz, 16 Aug 2011.
  1. Baz
    Baz I work for Corsair
    13 Jan 2005
  2. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    Pocket sized LAN rig. For such a tiny board that thing packs a mighty punch.
  3. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    disapointed at the sata speed no use putting a ssd in the machine
  4. TheUn4seen
    TheUn4seen What's a Dremel?
    22 Oct 2009
    Meh. Still waiting for something to take the crown from H55N-USB3, which basically means waiting for Gigabyte to release a Z68 ITX board (which was promised but not yet released).
  5. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    I love what Zotac have done. Shame about the SSD performance, but surely that is a bios related issue rather than chipset. Definitely a route I'd consider had I not already bought a S775/ION version of their board.
  6. Combatus
    16 Feb 2009
    Shouldn't matter too much if you have an older SSD such as the original Vertex or C300.
  7. Baz
    13 Jan 2005
    This. Similarly it'll only be peak read and write that are affected; general zippyness and responsiveness will still be great.
  8. b1candy
    b1candy What's a Dremel?
    21 Apr 2011
    So absolutely no mention of the CPU Turbo issue at stock, causing +300 MHz compared to other boards in multithreaded mode and a complete unfair advantage in benchmarks?
  9. longweight
    7 May 2011
    No Slot for a soundcard? That makes me a sad panda :(
  10. Ajhayter
    Ajhayter What's a Dremel?
    10 May 2010
    It's Mini ITX. Where would you fit one?
  11. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Use the optical out to a seperate DAC and amp combo? You can get those small enough to be mounted in a spare 3.5" bay.
  12. Instagib
    Instagib Minimodder
    12 Mar 2010
    These are cute, but until there are any decent mITX cases on the market i don't think i'll bother. Which is a shame, i quite fancy a tiny HTPC. I don't have the time (or skillz) to make one myself.
  13. Lance
    Lance Ender of discussions.
    6 May 2010
    If you want something powerful you pretty much have to go for a silverstone sg06 with its inbuilt powersupply. But that means your "cheap" little computer has suddenly just become alot more expensive.
    Coolermaster please come to my rescue and make a super-cheap mini itx case that fits a 5870.
  14. Bufo802
    Bufo802 Minimodder
    28 Jul 2008
    I wouldn't call the sg05/6 expensive, £70 with 300w or £100 with 450w isn't much different to a normal case+psu
