Case Mod - In Progress BORG COSMOS II - Reboot: Borg Cube Panel Part 01
Discussion in 'Project Logs' started by ASPHIAX, 16 Nov 2012.
  1. timerhan
    timerhan What's a Dremel?
    6 Nov 2012
    SSD nice look)))
  2. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Thanks ! Will have another small update tonight
    Thansk! I do want to dim the leds a little as its to bright right now !
  3. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Just a quick couple of pics from the front as it is now !
    Next post will be with the BORG logo in the door!
  4. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    Definately one of the best case mods I've seen so far.
    So simple yet so great.
  5. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Another Asphiax mod, YAY!!!
  6. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    I really like this, just read through the log, like any thing you enjoy, I was disappointed it ended so quickly ..
  7. Vandalo
    Vandalo Minimodder
    24 Mar 2011
    really a good job
  8. Pranja
    Pranja Blackwolf
    18 Dec 2011
    It has a right feel. Well done. :D
  9. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Thanks but there is so much better work around!
    Thansk bro! Seen you've been busy also! Signature growing quickly !
    I aint finished by a long shot , so be prepared for some more lengthy posts !
    Thansk man !
    Thanks ! I will be making the same mesh and plexi work around the bottom fan to make it more symmetrical. That should improve the overall design more !
  10. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Here is another update !
    I started on cutting out the rough shape of the plexi plate with the vinyl sticker.
    Then after endless filing it finally fitted perfectly !
    Mounted back the front onto the cosmos. It just needs some lighting now !
    Mounted the top led strip and the "rib" led strip for a quick fitting.
    I will make the bottom section like the top with the plexi strip around the psu.
    The purple glow will disappear as soon as I lightproof the door.
    Also the lines around the logo will be clean as I lightproof it.
    Let me know what you think so far !
  11. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    reeeaally nice! the shining edges is really making it glow! :D
  12. The_Crapman
    5 Dec 2011
    Lovin the build so far. I really like the purple hue, i think you should keep it to some degree.
  13. kelmannen
    5 Feb 2011
    yeah, i think ur right, the purple (in the right degree) looks awesome with the green! =)
  14. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Thanks, I am using normal blue leds. The same power as the UV but they dont fade as much!
    Thanks!
    Thanks! It wasnt on purpose the purple but its growing on me also. Maybe when I hook it up to the arduino The brightness will be less and its will blend in more.
  15. Pranja
    Pranja Blackwolf
    18 Dec 2011
    OMG,looks awesome.
    It only needs BORG Queen next to it. :D
  16. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    +18 rated log spotted!
    Good job!
  17. whyte
    whyte What's a Dremel?
    27 Mar 2012
    Amazing job! I wonder if you could replace the psu fan with one of the led enermax (or whatever you're using) fans so the front is more uniform looking. Anyways, loving watching this build.
  18. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Usually not a big fan of those light-it-up-like-a-Christmas-tree type of cases but yours is pretty cool.
    Keep up the great work. :thumb:
  19. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Thanks, maybe i could score one on Ebay.
    LOL, thanks but what do you mean ?
    Thanks. The PSU fan needs to be turned around anyway as i need to suck air through the PSU instead of blowing it into. 2 problems with changing the fan out. 1. Its a 135mm fan, dont think anyone makes them with leds. 2. becausse I need to turn the fan around the leds will be pointing inward. Good idea though! Keep em coming!
    Thanks! The lighting needs to be balanced as I do like lighting but it needs to blend in not dominate.
  20. Moddingboy
    Moddingboy What's a Dremel?
    19 Jul 2011
    Very cool project :rock:
