Case Mod - In Progress BORG COSMOS II - Reboot: Borg Cube Panel Part 01
Discussion in 'Project Logs' started by ASPHIAX, 16 Nov 2012.
  1. BOBDBONE
    BOBDBONE Owner at BS Mods
    4 Feb 2009
    This would make the Borg proud!
    Great work man. Super clean build. Love it. :thumb:
  2. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Thanks man!
    Its decision time. Should I go for the small or large window...
  3. gungravevn
    gungravevn What's a Dremel?
    12 Oct 2012
    I would say large since your SSD window is amazing.
  4. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Thanks !
    I am thinking of 2 windows now. 1 for the midsection and one long small one for the SSD's.
    Gonna look into this tonight.
    Keep you updated !
  5. Sissilisko
    Sissilisko What's a Dremel?
    26 Apr 2012
    i like the idea of two separate windows, could look great!
  6. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Thanks but plans have changed again !
    Will post an update soon.
  7. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    This is what I like about modding. You think you got something planned out and when you do the work, you have to think on your feet as it doesnt turn out the way you planned it !
    I was planning on doing a double window. The second window would have been where the X was marked with tape. (please note this is the rough cut, it needs a couple of hours of love to be perfect!)
    BUT ...
    Look at the size of that hole between the door and the case itself. In this picture you can look into the door.
    But even with a piece of alu posing as the rim I wanted to create, you can still look behind the door. This doesnt look right. Just does not have the feel I want to get with this build. It almost feels like an after thought.
    Also the second window would become very thin and cover most of the SSD's. It would let you see on the top left ...per-x and bottom right king... (normally Hyper-X and Kingston)
    This wont do either !
    The side is not the only one with a large crack. Gotta figure something out for this.
    So this is waht I will do. I will widen the rim for the window so that it will align with the midplate of the case. This will also funtion as a stop for the warm air. The 480 rads cannot push their warm air up anymore. 2 problems solved in one !
    It also just looks better imo. The SSD's will be visible only with the door off.
    Door Challenge nr 2 !
    As I have 2 x 480 rads in the bottom and the case comes with ventilation slots for 360's I need to change the door in that aspect also. The ventilation slots I have cut out for the window I will cut up and place them in the bottom.
    So the rest of my weekend will be spent getting this filed up perfect and glued into position.
    Not a small job. But still having fun !
    Omoobhs likes this.
  8. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Wow! Well done,mate. :)
  9. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Thanks man !
  10. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Not so spectacular work yesterday, spent most of the day planning stuff.
    Did do some work though!
    Location of the pump and the hole for the psu cables.
    I will make a alu wall between the pump and the psu for safety
    Tubing out of the pump that will be routed through the backplate into the rads
    Topside air intake and tubing passthrough!
    All sorts of cabling for cable management
    Time to get creative on the BORG door!
    Guess what's coming here ??
  11. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Sculpting a door?
    This thing looks beautiful, man.
  12. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Holy **** balls! This is awesome!
  13. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Thanks ! Yeah I got something special in mind for that door!
    LOL, thanks man !
  14. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Here is a quick update.
    Made the missing plexi ring for the bottom fan.
    Damn for forgot the mesh ..
    SSD drive bays. Love my alu bender
    Started on the door. This is the rough design for the work.
    The idea is to make a multilayered cube with lasers, uv plexi and some kitbashing.
    Need to decide if I am going for the white traditional panelling or the cube appoach
    Fan grills for the warm air of the 480 rad
    the cube approach
  15. KrunchR
    22 Apr 2008
    The cubes are cool looking. Could you do a mixture of both? Cube and panels?
  16. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Yeah, the mesh is going to get some panelling and pipes that go from the surface "into" the door. Also got lots of small modelling stuff that can go on the cubes to break the design a little.
    Here is the inspiration for this section
  17. Petrol head
    Petrol head What's a Dremel?
    26 Oct 2011
    The case looks amazing, can't wait to see the end result. Great attention to detail.:rock::thumb::dremel:
  18. The_Crapman
    5 Dec 2011
    Congrats on the motm nomination. Got my vote :thumb:
  19. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Thanks! Cant wait to see how the foam will look when fully covered with cubes and panelling. Got 15 meters of cube pvc rods coming in today!
    Thanks man ! Lots of excellent mods again this month!
  20. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Sorry people that I havent had an update for you recently !
    End of year is always killing with sales targets to be made and annual reviews with employees. There is one in the making but it will take some more time.
