Scratch Build – In Progress CaseMod: Cellarette (FINISHED)
Discussion in 'Project Logs' started by Pfaffen, 10 Aug 2011.
  1. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    Here is a general layout shot.
  2. Pranja
    Pranja Blackwolf
    18 Dec 2011
    With every picture it becomes even more beautiful.
  3. Pfaffen
    18 Mar 2007
    Pranja,
    Thanks! :D
  4. The_Crapman
    5 Dec 2011
    I wish i was this good with wood. I would have had quite a few less tellings off from my dad! lol
    Awesome design man. Can't wait to watch it develope!
  5. Pfaffen
    18 Mar 2007
    Well, made some progress so here are the new pics.
    Here is the glue up. I normally don't use glue, but I wanted the grain to run around the case, so I built it with the mitered corners.
    Here is the case out of the clamps.
    Applied some boiled linseed oil to it. You can see the difference immediately.
    While the oil is still wet, you can see the reflections of the table.
  6. Pfaffen
    18 Mar 2007
    After the oiled dried, it was time to cut the lid from the body.
    Then it was on to the hinges. I went with invisible hinges... I was not fond of the hinges showing on the outside of the case.
    Here we are at the drill press, plowing out the wood for the hinges for the lid. The case was another issue.
  7. Pfaffen
    18 Mar 2007
    Here is the case with the hinges and the lock installed.
  8. Pfaffen
    18 Mar 2007
    Now to mount the top to the base. Remember the cherry hold downs I made a few months ago???
    Well, now I get to use them...
    Here is the bottom of the case
    and here are all the hold downs applied.
  9. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    Love it! The BLO on that looks fantastic!
  10. KidMod-Southpaw
    28 Sep 2010
    Good lord, this is amazing, well done!
  11. Pfaffen
    18 Mar 2007
    Here is the moulding dry fitted.
  12. Pfaffen
    18 Mar 2007
    Here are the supports for the Mobo and HDDs.
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    Superfine :).
  14. Pfaffen
    18 Mar 2007
    I had to make a little stand for the PSU. So I took some Cherry and Oak and made a corner support.
    Just about as long and as wide as the 800W PSU stand in.
    Then it was on to measuring the power, reset and the LED lights. The buttons were 3/4" and the LED brackets were 1/4".
    I gold leafed the buttons and then sprayed them with lacquer... not sure if I like them or not.
    Here is the faceplate for the Blu Ray/DVD, 35 in 1 Card Reader, Power and Reset buttons and the HDD and Power LEDs.
    Here is the support in postion.
    Here is the case with most of the equipment in and the cables (semi-organized)
  15. Pfaffen
    18 Mar 2007
    Ok,
    Here they are just a little bit more organized.
    and the faceplate back in place.
  16. Pfaffen
    18 Mar 2007
    KidMod-Southpaw,
    Thanks...
  17. Cheapskate
    13 May 2007
    Looks lovely with the molding in place. If the gold leaf doesn't work, you could use some brass plugs and seat the switches behind them. That would match the hardware.
  18. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Looks really good... But I don´t know about the gold leaf. Have to see it IRL I guess. A brass plug or something maybe, like cheap says. Shame there´s not too many brass switches out there
  19. Pfaffen
    18 Mar 2007
    Cheapskate, great idea... I'll see what I can find...
    David likes this.
  20. David
    7 Apr 2009
    Loving the work.
    Subbed.
