Guide Make your own USB LCD controller!
Discussion in 'Modding' started by ch424, 23 Jun 2006.
  1. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    towards the 0v side :)
  2. HellraiserUK
    HellraiserUK What's a Dremel?
    19 Sep 2006
    Works now - I had a duff LCD :( Now time to get the rotary encoder fitted :)
    Cheers to ch424 for an ace mod, this is definitely quite snazzy :)
    Hellraiser............>
  3. ch424
    ch424 Design Warrior
    26 May 2004
    Well, glad it works, and cheers to everyone else for helping out here! :thumb:
  4. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    Anyone having it working with the 18f4550 hex file?
    Im about to try it myself, il tell you how it goes.
  5. Scorpia
    Scorpia What's a Dremel?
    17 Jul 2006
    Anyone had any luck with the 18f4550 hex file?
    im wondering how it went.
    Let me know
    Scorpia
  6. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    First off I have to thank ch424 so much for this excellent controller and all his help in getting mine going. :thumb:
    Here are a few shots of my setup that I have been working on over in my thread > link < :
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    I know the images are terrible but there is nothing I can do about that. Thanks again ch424
  7. Warrior_Rocker
    26 Jun 2005
    Thought I would add a few more pictures of the actual pcb:
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    again a special thanks to ch424
  8. iiiibadboyiiii
    iiiibadboyiiii What's a Dremel?
    26 Aug 2006
    PIC18F2550 LCD C18 HID Source Code
    Hi ch424!
    Sorrz for the time delay; ive been kinda busy! Just continuing my project now...
    I never really got an email...Wierd!
    If you dont mind please would you send it again to rbroich@gmail.com !
    Thanks,
    Rene
  9. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    When I went to "Config Memory", some of the addresses were not there, like 300001, 300003, 300005, 300009, 30000B, 30000D. Also, when changing the value, am I right in assuming that CH424 just listed the last 2 digits of the hexidecimal value? I.E., the value for 300000 comes up as 0x3fff, would I change that to 0x3f20? Thanks for any help.
    I built the programmer based on the Olimex design (JDM? ), which seemed to work well. WinPic detected it and wrote the code to the PIC, but I want to make sure I made the right settings for the memory config and to make sure I wasn't missing something since some weren't showing up.
  10. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    Omg,awesome work! :naughty:
  11. ch424
    26 May 2004
    One~Zero, I actually have no idea I'm afraid. Just look at the screenshot I posted. Edit: does the circuit actually work or not?
    iiibadboyiii I'll have a look....
    Edit: email re-sent Rene.
  12. One~Zero
    9 Sep 2004
    No worries, it was my fault :blush:
    I didn't load the .dev package for the 18F2550. Came up just like your screenshot (more or less). Said it wrote to the IC fine, just need to build up the rest of the circuit to test. Thanks.
  13. acidice333
    acidice333 What's a Dremel?
    27 Dec 2006
    I have a LCD, but it is wired up as SPI so I have 4 wires to hook up (power,ground,data,clock). Is the firmware modifiable for SPI?
  14. ch424
    26 May 2004
    acidice333, no I'm afraid not. If you want to do that, you might as well start from scratch - what are you using at the moment?
    One~Zero, glad you got it sorted... remember to post pics!
    Edit: willyf1, who are you talking about?
    ch424
  15. ch424
    26 May 2004
    Bindi, please can you stop deleting posts that I refer to!? It makes me look like I'm taking the piss, when I actually wanted to help out....
  16. acidice333
    27 Dec 2006
    I'm using a HD44780 display, with a daughter board converting it into a SPI connection. It is connected to a PIC18F4550, and just displays text. I can go back to connecting all the pins of the HD44780 but I would perfer fewer wires.
  17. acidice333
    27 Dec 2006
    Is it possible to get the firmware source code? Thanks
  18. Warrior_Rocker
    26 Jun 2005
  19. acidice333
    27 Dec 2006
    Nevermind about me wanting the firmware source, I have made my own code for the SPI wiring (2 wires to the PIC) and most of the commands are working.
  20. ch424
    26 May 2004
    Brilliant acidice333 - I sent it anyway, if you're interested.
    Warrior_Rocker, thanks for the heads up! Looks pretty cool, especially as he didn't use USB hardware!
