Scratch Build – In Progress Metaversa 02: Ada
Discussion in 'Project Logs' started by Nexxo, 21 Jan 2014.
  1. ChromAnomaly
    ChromAnomaly What's a Dremel?
    7 Nov 2013
    Really wish I had a friend with milling equipment . . . And holy crap, those aluminum plates must have cost a small fortune! Really intrigued by the design though, and (as everyone else has said) looking forward to seeing how this turns out.
  2. Nexxo
    23 Oct 2001
    Ask Skyrip. He does CNC jobs for a very decent price. :)
    Aluminium is ridiculously cheap, actually. The big 12mm plates cost no more than £60,--.
  3. ChromAnomaly
    7 Nov 2013
    Shipping to the US would probably make Skyrip's prices less appealing . . . but I will ask anyway since I have a couple pieces I've been trying to figure out how to cut with just a hand drill and a scroll saw :)
    Ok, that's not too bad for the aluminum. I double checked the prices here and realized that anything with a max dimension less than 12" is pretty reasonable. It does seem to skyrocket for anything larger though, which is the price that stuck in my head.
  4. Nexxo
    23 Oct 2001
    Prices do indeed go up exponentially as the slabs get bigger and thicker, so you have to factor that into your design. There is also an upper limit to the size that smaller workshop CNCs can manage.
    You also want to make sure that your piece can be milled from a single side, if possible. Flipping the part over to do the other side means having to mount it in exactly the same location as it was before, and that is hugely laborious.
    You will note in Ada that most parts are duplicates. There are eight parts but there were only five different designs involved (with one being just a mirror image of the other). All these tricks made it easier and cheaper to produce.
  5. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    Nexxo what are the 8 main support bolts button head brass ??
  6. Nexxo
    23 Oct 2001
    They're "gold" anodised titanium, meant to look like brass, but are actually somewhat lime yellow. Unfortunately the colour can vary depending on the voltages applied in the anodising process and you can never tell by the images on a website exactly what you will get. After the test fit I put them back in their bag and I'm returning them (the advantage of titanium is that they are scratch proof). On the image below you can see the bolts compared to some brass screws I happen to have:
    Note how the bolts are much more yellow-green than amber. On its own not a huge problem, but it will contrast too much with other brass parts.
    Luckily Birmingham has a lot of jewellery and metal industry. A local fasterer company is going to manufacture some brass bolts for me to my spec, as they do not exist off-the-shelf. It will be slightly more expensive than the titanium bolts, but I really need them to look right, especially as the reservoir will also be brass (I'm stripping the nickel plating).
  7. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    Ahh was wondering as I must use 1000's of fixings in a year and never seen any like that :D well not in brass. :p
  8. Cheapskate
    13 May 2007
    Ah, I see a light in the darkness!:lol: Finally!
  9. Boorach
    Boorach Minimodder
    16 Feb 2013
    Looking fantastic so far, looking forward to following your progress.
  10. Wirecase
    Wirecase What's a Dremel?
    16 Jan 2014
    Awesome work man, keeping track!
  11. Combatus
    16 Feb 2009
    Stunning start sir. Watching this one!
  12. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    Insta-sub
  13. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Agreed!
    I remember Metaversa 01, I now feel old and shall return to my armchair.
  14. Nexxo
    23 Oct 2001
    I remember my Commodore 64! I'm ancient! :p
    I have just had my brass Aquatube stripped from its nickel coating. The brass underneath is beautiful --it looks more like gold. Will post pics when polished and brushed. :)
  15. Umbra
    Umbra What's a Dremel?
    18 Nov 2013
    Looks Klingon, definitely Klingon.
    Klingon copyright, we will sue!
    Jeez, they cost enough :D
    Great work, subbed :hip:
  16. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    What? A Nexxo MOD thread, oh chap, you've another subscriber!
    Lovely work on those milled parts, love the background info and the design looks very unique indeed!
  17. ChromAnomaly
    7 Nov 2013
    Hmm, now that you mention it . . . yes, I agree. Definitely Klingon.
  18. Nexxo
    23 Oct 2001
    Pah! The Klingons copied me! :p
  19. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    thought Pah was Bajoran not Klingon :D
  20. Darkened
    Darkened Minimodder
    28 Feb 2004
    Metaversa 2 - Awesome, awesome to the max!
    I'll need to get my modding spirits up (again), so yeah, I'll be definitely watching this one.
    Darkened
