Case Mod - In Progress Official "John Hanlon Fund Raiser" PC Build (Thank you Mach!)
Discussion in 'Project Logs' started by mnpctech, 23 Feb 2012.
  1. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    This is a great project by all means.
    Of course 5 *****
  2. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    LOL... I know; I'm just trying to find ways to help even if the RAM is not compatible with the HW being used on the build.
  3. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    I was telling Cheap that i have 4 new blue R4 fans that id like to donate and would like to make grills to go with them. If they are single mounted fans i can make ones to just cover the single fans, but if they are mounted on a rad, this is what that looks like
    I can make up to a 360 grill (like this or wider for mounting a rad with) with the continuous design. If there is a theme i would like to match the design or at least the colors. Cheap did mention he thought it would be 'red white and blue'.
  4. DarthBeavis
    DarthBeavis What's a Dremel?
    29 Aug 2008
    that would be awesome. I think we are mounting a 240 rad internally so having an internal grill would be great will look to see what other fans we need. Blue I bet would go well
  5. jhanlon303
    7 Sep 2006
    OH! Hexagonads. Excellent. Better look than just holes.
  6. Cheapskate
    13 May 2007
    OW...
  7. jhanlon303
    7 Sep 2006
    I just love auto suggestions in Firefox. Only have to type part of a word and it fills in rest! :duh:
    Someone should have tested this a little more. :sigh:
    the john
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    Hexagonads Cheesecake :D:lol: awesome word of the day. :hehe::D
    Apparently they are a special screw unless a parts place listed them wrong. :D
  9. Cheapskate
    13 May 2007
    Definitely wouldn't want to sit on them accidentally...
  10. BOBDBONE
    BOBDBONE Owner at BS Mods
    4 Feb 2009
    ROFL :D
  11. Furball Zen
    25 Jan 2012
    Makes me feel good to be part of the creation of such a term ;)
  12. rchiileea
    rchiileea Minimodder
    11 Jan 2008
    ecommunity... is what is missing from the world these days, glad to see it still alive
  13. Cheapskate
    13 May 2007
    Bill's really swamped right now and he asked me to post relevant stuff.
    -Earlier, I glued together a big 4" x 1" brick.
    -Of course, It needs a transparent window to see the condition of the copper, so I had to shave the opaque white down to 1/16 of an inch. That got messy fast. The fly cutter can really throw plastic around.
    -The first pass is in 3/8" I had to use this bit because it's the only one that can cut more than 3/4" deep.
    -1/8" pass. I'm keeping this one simple. Just a side to side flood across a big slotted plate.
    -This is after the last session with a 3/32" bit. Next I use all the little holes to drill the mounting points.
    ...and run the vacuum. Seriously, that was messy. I should have some copper ready to mill tomorrow.
    Waynio likes this.
  14. jhanlon303
    7 Sep 2006
    Last water block you made for me was during a hurricane with no electricity! Most excellent. My thanks.
    the john
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looks really nice cheaps :dremel::rock: & getting it down to 1/16" wouldn't have been an easy task. :eeek::)
  16. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Neat job, yes!
  17. Cheapskate
    13 May 2007
    @John - :lol: Cut manually too.
    @Waynio - Really easy, actually. The tough part was that cutting left to right tossed hot plastic string at my face.
    @Nutman - Thanks.:D
  18. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Do you recycle your acrylic shavings into glue?
  19. jhanlon303
    7 Sep 2006
    Back when I was seriously into plastic model cars, we would make a great filler by simply adding pieces of the plastic sprue into bottles of liquid cement. You could make it as thick as you needed. plastic bondo! stayed on forever.
    john
  20. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Might be time to splash out? Remember, you only get ONE spare eyeball!
