Scratch Build – In Progress Onwards and upwards by Parvum Systems : Complete
Discussion in 'Project Logs' started by imersa, 9 Mar 2013.
  1. imersa
    imersa Parvum Princess
    9 Apr 2009
    Ah thanks man! We both just rocked the :jawdrop: face, haha!
  2. that_du^de
    that_du^de give your head a wobble
    29 Nov 2010
    imersa, we dont do signage its all aerospace work from flat sheet alu,brass,copper and a special materiel we call "alpolic"(made by mitsubishi chemical) its a 4mm polymer sandwich that is bomb proof!
  3. imersa
    9 Apr 2009
    Ok well that makes signage sound like childs play :D
  4. imersa
    9 Apr 2009
    14 March Update
    Here we are again, stayed after work for a few hours to get this update together.
    The main focus for this update was to make a custom reservoir. We decided to do this for a number of reasons. Mainly because they look amazing but also because we are going to be pretty tight for space once we do a double loop.
    So we started by cutting a test piece of 5mm acrylic. The same size as the full reservoir to ensure a good fit:
    A little later and the tool paths are set:
    Onto the milling. Tools for the job, 2mm & 6mm:
    Lots of mess when milling thick acrylic:
    A little more cutting:
    After a little cleaning down here is the finished item. We are really happy with results. After the o ring is installed and a little tapping we are in business:
    Next the Gentle Typhoon fans are installed in the front:
    Fitting really nice:
    Then we cut the test top panel for the case. The top section for the case will be two layers. The first is this 5mm frosted clear. This also doubles as the lid to the reservoir. We went with this to match the frosted EK blocks and add a somewhat gray tone to the build:
    Thanks again for reading. Can't wait to see fluid in this thing.
    Next you can expect the second layer to the top & the top chamber.
    Thanks for reading :rock:
  5. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Now how did i know this was coming......:thumb:
    :dremel:
  6. Cheapskate
    13 May 2007
    Itty bitty reservoirs cut from a big chunk of plastic. I like!
  7. Father-Time
    Father-Time Minimodder
    23 Feb 2004
    Awesome res, just bloody awesome!
    Rest of the build is ok too i guess :worried:
  8. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Loving this build dude.. Them res are swcheeeeett!! :D
  9. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Ohh my lord :D!
    How could i ever miss this :D?
    Are you the maker of pavarum cases ?
    SUBBED!!!!!!!
  10. Si_the-dude
    Si_the-dude Techaholics Anonymous. 0 days clean
    17 Dec 2012
    No idea how this one slipped by. I am absolutely speechless :jawdrop:
  11. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    the Res is insane.... What a pleasure just looking at the picture..
  12. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    I love this build. The placement of components it really well thought out. Great job you two.
  13. imersa
    9 Apr 2009
    Haha I don't know how you would have seen this coming ;)
    Thats the way to do it! Can't wait to pop some fluid in there.
    Nailed it! I'm happy with parts being awesome and the rest being OK! ;D
    Thanks man!
    I suppose it may have been missed as we are flying through. Our deadline for the build is next Friday as I will be using it at the iSeries event.
    I am indeed one of the Parvum team!
    Thank you man.
    I'm really stoked on it. Was nice to break up the 45 angles of the case with a little curve.
  14. imersa
    9 Apr 2009
    Damn was just quoting for replies and missed your one :D
    Thanks for the kind words. Makes it super easy to build with the extra space in the back!
  15. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
  16. WhatTheTech
    WhatTheTech Macmodder Addict
    18 Dec 2012
    Nope. Just stop. Desist immediately.
    My eyes can't take the awesomeness any more.
    :D
  17. kier
    kier -----------------
    1 Mar 2011
    Love it...great res
  18. Pranja
    Pranja Blackwolf
    18 Dec 2011
    That is one sexy reservoir.
  19. imersa
    9 Apr 2009
    Ah thank you! We must not desist however! More to come!
    Thanks kier! We will have your stuff sorted real soon!
    Thank you, really happy with the result. Can't wait to get some Mayhems in there!
  20. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
