Case Mod - In Progress Project: AnG3L -MOTM April 2009 Winner- (FINISHED!!! June 19)
Discussion in 'Project Logs' started by AnG3L, 19 Mar 2009.
  1. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Thanks man! I still missed the point though. Theres also the activity led....
  2. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
  3. AnG3L
    19 Mar 2009
    Thanks dawg, but there it says + - for the Led! I am confused! Thanks though I 'll find the way out! :)
  4. AnG3L
    19 Mar 2009
    Here are the attachments I made from acrylic for the wings (measuring, bending etc)
    After I painted them black, I attached them on the wings and after on the case. I also
    added some epoxy glue, just a tiny piece to hold the wings in place!
    Here they are finished after the varnish for metals !!! :rock:
    Feel free to comment pls!!! Thanks ! :thumb:
    stonedsurd likes this.
  5. stonedsurd
    11 Mar 2009
    Whoooaaaaaa!
    That looks EPIC!
  6. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    awesome :clap::clap:
  7. AnG3L
    19 Mar 2009
    :) :) :) Thanks guys!
  8. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    HOLY ...! :jawdrop:
  9. AnG3L
    19 Mar 2009
    :) Here's a video of the bezel's creation
  10. AnG3L
    19 Mar 2009
    I am in the search of 2 Blackfire4 UV LED 120mm Fan Orange and I cant find any!!!
    Is there any good man out there to be kind enough to send me 2 pls as a gift?? :)
    tyrandan likes this.
  11. AnG3L
    19 Mar 2009
    Or does anyone knows where can I find UV orange visible spray paint pls? Any help will be good!
  12. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    very unique, cool, interesting, and the colors pop nicely... AC Ryan have UV paint, but not spray cans...
  13. AnG3L
    19 Mar 2009
    Thanks Mansueto! I know that, I found in one place but they want 66Euro extra for safety package and 20 Euro for shipping extra!!!
  14. mansueto
    31 Aug 2007
    Ouch, that's a bit crazy... does it have to be UV or can you just use the really bright florescent paint? That may ruin the look your going for?
  15. AnG3L
    19 Mar 2009
    I need the uv paint and for some other parts which they will.... glow! :) It will be nice if I could find an orange uv acrylic....
  16. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Search for UV orange acrylic on ebay, I managed to find a few different paints.
  17. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    AnG3L look @ this UV painting i think its what your are search :thumb:
  18. AnG3L
    19 Mar 2009
    Thanks man but I already have these but the orange....is gone! :p In my country I cant buy only the orange I need to buy all the set again :(
  19. Guest-23315
    Guest-23315 Guest
    ^^ Ask AC-Ryan directly if they can send you a UV orange one?
  20. AnG3L
    19 Mar 2009
    :) Ok, I did that now I am waiting for an answer! {cross fingers}
